Starter problem.
Old Oct 11, 2010 | 06:20 PM
Butchi's Avatar
Butchi
Default Starter problem.
Hello.
Got a problem....I think. I have a 1 year old starter motor. I have heat wrappet from down pipe and under the starter. There are also a heat shield over the starter.
When the engine is cold the car starts emmediatly. The starter runs very good. BUT, when I have been driving for couple of minutes, then turn of the engine and try to start it after some seconds it wont start because the starter doesent have the power to turn over the engine.
If I wait 10 minutes it runs again. The battery is good, 12.7 volts.
Can it be the starter that is cooked already? Just after a year?
BR Butchi
Old Oct 11, 2010 | 07:48 PM
Rs-Simon's Avatar
Rs-Simon
Mine did the same, I replaced the live and earth cable and that sorted it.
Old Oct 12, 2010 | 04:46 AM
Butchi's Avatar
Butchi
Ill do that. One question please. You wrote that you replaced the LIVE, whats that?
BR Butchi
Old Oct 15, 2010 | 07:17 PM
Rs-Simon's Avatar
Rs-Simon
BR Butchi
The red cable that runs from the battery to starter motor.
Old Oct 16, 2010 | 04:00 PM
xrmalin's Avatar
xrmalin
Your lucky if it lasted a year my zvh turbo in the estate did 2 starters in a week absolutly fine when they were cold but after a 20 minute drive or so if you switched it off it wouldnt turn over for love nor money
Old Oct 16, 2010 | 04:27 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Buy diesel starter ! This was a common problem.this will sort it.wires are worth checking.
Old Oct 16, 2010 | 04:30 PM
Butchi's Avatar
Butchi
Ok. I have replaced the earth and live with much bigger cables. I have also bought a heat carpet that can stand 1100 degree Celcius. The starter is completle hide under that heat carpet.
Hope this will solved the problem.
Old Oct 16, 2010 | 04:44 PM
essexRSTSouthend
If not then do the above.
Old Oct 16, 2010 | 05:19 PM
Butchi's Avatar
Butchi
Diesel starter, from which year and model?
Br Butchi
Old Oct 16, 2010 | 05:35 PM
essexRSTSouthend
ill find out for you
Old Oct 16, 2010 | 05:49 PM
essexRSTSouthend
1993,1.8 diesel. off a escort/van,as they used same starter
Old Oct 17, 2010 | 06:35 PM
Butchi's Avatar
Butchi
Thanks.
I have drived the car now. The starter runs very fine now. No heating problems anymore. Im very pleased.
Thanks.
Br Butchi
Old Oct 17, 2010 | 09:05 PM
essexRSTSouthend
Was it the wires?
Old Oct 18, 2010 | 04:02 AM
Butchi's Avatar
Butchi
Dont know if it was the cables or the heat carpet round the starter. But it was a sucess anyway.
Br Butchi
Old Oct 18, 2010 | 06:22 PM
xrmalin's Avatar
xrmalin
I tried a diesel starter and its too long to fit inside the down pipe that might be because mines a zvh though
mark.
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
