trying to choose a turbo for my 1.6 cvh ......
Old Oct 10, 2010 | 12:50 PM
s1cab's Avatar
s1cab
Default trying to choose a turbo for my 1.6 cvh ......
I have anti-lag atm on p8 cossie managment. I was running a stage 3 T3 but wanted to go for more horses.. I'm trying to choose between a T34.48 (with maram shaft for the anti-lag) or do away with the anti-lag and go for either a GT28 or a GT30.any help or comments will be appriciated as im struggling to make a choice. Aiming for 310bhp-330 bhp
thanks
Old Oct 10, 2010 | 03:03 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Id much rather have a decent T34 over a ceramic Turbine.
However T34 with 48 will be hard to get that power would need a .55 or .63
Old Oct 10, 2010 | 03:09 PM
gus's Avatar
gus
why do you want that much?
for me the power is irelevant (sp) i wanted a fast, responsive engine
wasnt too worried about how many bhp's it has
but i wouldnt worry about als (its just a gimmick, only suited to rally stages imo) and i would go for a roller bearing turbo
but thats me
Old Oct 10, 2010 | 03:16 PM
jonny s2's Avatar
jonny s2
i agree with gus on the spool up, my t34-48 seems not too bad tho lol, the roller bearing jobbies seem to always need rebuilding tho after 3k, ive heard a few complaining now about early rebuilds
Old Oct 10, 2010 | 03:29 PM
gus's Avatar
gus
really!!!!
o dear
Old Oct 10, 2010 | 06:13 PM
project rs's Avatar
project rs
we've battered a gt2871 for 10000 hard miles including mapping and pod action and so far it's been fine and is making good power on the zetec, as to op's question theres not much different between a gt28 and the t34 you mentioned so only thing is how much you want to spend and both will only make around 300 on a 1.6
Old Oct 10, 2010 | 06:18 PM
Rob_DOHC's Avatar
Rob_DOHC
Don't think he mentioned anything about ceramic turbines lol
Rob,
Old Oct 10, 2010 | 06:19 PM
Rob_DOHC's Avatar
Rob_DOHC
And will a .48 housing on a t34 make 250-270 brake happily? like gus says im more interested in response than power.... or would a stage 3 t3 be a better weapon?
Rob,
Old Oct 10, 2010 | 06:31 PM
gus's Avatar
gus
t3 would be working hard i would of thought
Old Oct 10, 2010 | 06:32 PM
studabear's Avatar
studabear
is the ceramic turbine to cope with the extra heat created by the anti lag?
Old Oct 10, 2010 | 06:56 PM
rsmark86's Avatar
rsmark86
a t3 could get to 270bhp but only on the best of engines and would be working flat out....
270/280bhp was what i was looking for and i sold the stage 3 t3 and opted for the t34.48 for a bit of reliablity ..... and im going for better manifolds to help spool up times
Old Oct 10, 2010 | 07:03 PM
Rob_DOHC's Avatar
Rob_DOHC
Ceramic turbines do cope with heat better, but they are generally lighter and thefore aid spool time, i wouldn't have thought they would be very suited to anti lag though,
Maram is an alloy used to cope with anti-lag...
Rob,
Rob_DOHC's Avatar
Rob_DOHC
Cool, cheers
Rob,
Old Oct 10, 2010 | 07:11 PM
Versus_Creations
Ask me a question!
Id dont agree, i use my als on most track days i go on. Even more on the road.
rsmark86's Avatar
rsmark86
they can be had for same money as a stage 3 t3 aswel.... i got the nms stage 6 spec cvh turbo from olies red s1 for £450 and came with manifold and custom made down pipe and braided hoses for boost controller ect.....
its rated between 280/300bhp.... full stage 3 hybrid t34 with .48 rear and actuator set at 2bar lol
Old Oct 10, 2010 | 07:15 PM
Rob_DOHC's Avatar
Rob_DOHC
Whats a stage 3 t34? 360 thrust i guess.... what else?
Rob,
Old Oct 10, 2010 | 07:19 PM
rsmark86's Avatar
rsmark86
im sure he said its bigger compresser with the cut back blades ect.... but its the one that olie ran with around 300bhp.... and the guy i got it from only ever got his car mapped with it and made 289bhp with a bleed valve and would boost 2bar and drop to like 1.5bar so he said if i had a decent boost controller it would hold like 1.8/9 bar and boost to around 2.1bar lol
Karlos G's Avatar
Karlos G
Balls Deep!
.63 Exh and a bigger Comp wheel I guess?
Old Oct 10, 2010 | 07:44 PM
s1cab's Avatar
s1cab
i couldn't believe the difference when i first used my ant-lag... makes the car feel so alive so T34 it is.. but - .48 , .55 or .63 ? imo the .63 would proberly be far to laggy so whats the difference between .48 and .55 ? would i see over 300bhp with the .48 or will it need a .55 ? i had a stage 3 T3 and got bored of the power so thats why i want a bigger turbo also once mapped i want to leave it alone for a while. cheers for replies everyone ^^
Old Oct 10, 2010 | 09:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
IIRC Christian recommends a 0.48 for just over 300bhp, D4 RST used a 0.63 and made no power until like 5800rpm or something like that lol
Old Oct 10, 2010 | 10:00 PM
s1cab's Avatar
s1cab
D4 RST he still around ? .48 maybe the better choice then.
Old Oct 10, 2010 | 10:11 PM
jonny s2's Avatar
jonny s2
D4 is still about seen him post not so long since, lol
48 will be better, read somewhere that someone had a 63 and changed to a 48 and had better results, think was tony turbo/christian
Old Oct 11, 2010 | 12:09 AM
rsmark86's Avatar
rsmark86
.48 but if your running anti lag then a mar-m 247 shaft .55 turbo would be nice but will cost alot unless you get it second hand
Old Oct 11, 2010 | 07:43 AM
stuart collins's Avatar
stuart collins
i no where the d4 is lol, wat a mess lol or was
Old Oct 11, 2010 | 07:46 AM
rsmark86's Avatar
rsmark86
well we all know hes not going to pod on the 24th lol
Old Oct 11, 2010 | 09:05 AM
Rob_DOHC's Avatar
Rob_DOHC
lol
Old Oct 11, 2010 | 11:53 AM
s1cab's Avatar
s1cab
D4 RST =
Old Oct 11, 2010 | 12:00 PM
Rob_DOHC's Avatar
Rob_DOHC
Found him
Old Oct 11, 2010 | 12:02 PM
s1cab's Avatar
s1cab
Originally Posted by Rob_DOHC
Found him
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
