Power steering problem
Old Oct 8, 2010 | 10:52 PM
caprizetec170's Avatar
caprizetec170
Default Power steering problem
ive got an 84 capri2.8 in which the steering turns one way faster than other with a lot less force anyone any ideas what wrong. it the same both ways with belt disconnected
Old Oct 9, 2010 | 08:26 AM
Have you counted how many turns it is to the left and right.
Old Oct 9, 2010 | 08:28 AM
i would take the steering column off the rack, jack the car up and turn the wheels with your hands to see if you can feel it in the rack. If it feels ok you know there is a fault with the steering column.
Old Oct 9, 2010 | 10:31 AM
A restriction in the pipes is the cause of this, most likely in the rack pipes.
Old Oct 9, 2010 | 12:13 PM
caprizetec170
thanks lads cant fell andiffence in rack side to side and it is centered 1.6 turns each way have replaced some of pipes already as they were kinked thought that was problam
Old Oct 9, 2010 | 12:19 PM
Have you tried a different pas pump. I dont think its this but might be worth a try.
Old Oct 9, 2010 | 03:37 PM
studabear's Avatar
studabear
valves in the steering rack playing up
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
