My 24v Cosworth Home Grown Single Turbo Conversion
Old Oct 8, 2010 | 08:00 PM
Damocos's Avatar
Damocos
Default My 24v Cosworth Home Grown Single Turbo Conversion
All work done by myself and a good friend, all home grown.........
Started with a BOB 24v, and run on a KKK27 Turbo from a commercial lorry application. Custom made manifold from gas pipe fittings, all tig welded. External 50mm wastegate and screamer pipe, scooby 440cc side feed injectors, and lots more. Running on Emerald management and other uprated goodies.
Old Oct 8, 2010 | 08:16 PM
Damocos's Avatar
Damocos
See anything wrong with this pic............
Major schoolboy error.....!!!!!!
Did change it slightly......
Remade the plastic inlet out of steel....
Universal 3" intercooler......
2.5" boost pipes.....
Old Oct 8, 2010 | 08:25 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Nice work mate look forward to seeing more pics!
Old Oct 8, 2010 | 08:26 PM
COLEYST200's Avatar
COLEYST200
interesting
Old Oct 8, 2010 | 08:40 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
fucking awesome ,
i love these home brewed lowbudget builds where trial n error are all part of the mix
the motor just stock ? expected power ??
beef
Old Oct 8, 2010 | 08:46 PM
airbrushfx's Avatar
airbrushfx
when saying gas fittings for the manifold what size?
Old Oct 8, 2010 | 08:51 PM
Damocos's Avatar
Damocos
Wiring loom went on a hefty diet, also found some dodgy 20 year old wiring issues....... probably explain my erratic fueling for the last 3 years......
New injector loom wires, along with new Scoob plugs.....
The original ford injectors, only flow 191cc per min.....
Scooby STI 440cc replacements, all cleaned and tested....
Time to pull the lump out to mod the sump and change clutch for an AP 4 paddle....
Sump drilled and modded for oil return....
Old Oct 8, 2010 | 08:55 PM
Damocos's Avatar
Damocos
Originally Posted by -beefy-
fucking awesome ,
beef
Yep, stock motor...... Sticking to low boost, 10psi max i think Should stay together but time will tell.......lol
Got no idea on power output as it needs to be mapped and i need some dollars and a day to trailer it upto Emerald's to sort. Hopefully wont be too long till that day comes as its ready to go.
Old Oct 8, 2010 | 09:02 PM
-beefy-'s Avatar
-beefy-
damo , how you feeding from the other bank ?
round the back of the engine or under the sump fella ?
beef
Old Oct 8, 2010 | 09:03 PM
Damocos's Avatar
Damocos
Do you know what...... i cant remember atm, im sure they are 1" 3/4 but will have a look at the spare fittings i have left. Used these as they are thicker and more able to withstand extreme heat compared to thin tubular pipes.
Old Oct 8, 2010 | 09:05 PM
Damocos's Avatar
Damocos
beef
Using a link pipe from the R/H bank under the gearbox and then very tightly up to meet the manifold along side the 3" downpipe........... pics will follow.
Old Oct 10, 2010 | 08:28 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Good stuff! like the use of the subaru injectors, did you need to modify the rail deeper or are they a straight swap? i ran those on a zetec turbo once. Im sure it will make over 300 bhp and 300+ ftlb of torque at 10 psi, will be good to see some dyno graphs. keep up the good work.
Old Oct 10, 2010 | 12:58 PM
wess-rs's Avatar
wess-rs
awesome project!! i will keep an eye on this!
Old Oct 10, 2010 | 01:07 PM
cossie04's Avatar
cossie04
Awesome Work m8, look forward to seeing this in the flesh!
Old Oct 10, 2010 | 09:19 PM
Damocos's Avatar
Damocos
Engine nearly ready to go back in, modded one of the oil returns from the head to take oil breather.....
Good old copper pipe fittings.....lol
Engine cleaned ready to go in......
Cosworth oil breather....
Adjustable fuel pressure regulator....
The remade inlet pipe, original was plastic
And this was the original vis unit that i took the gubbings out and blocked the holes as not needed with forced induction.
Manifold all wrapped.....
Wastegate and screamer pipe on......
Old Oct 10, 2010 | 09:29 PM
COLEYST200's Avatar
COLEYST200
looking good mate i will be running befor the week is out at this rate
Old Oct 10, 2010 | 09:45 PM
alanfordtw-15's Avatar
alanfordtw-15
great to see this car is still being developed, remeber reading the original build with the boa engine and it was and still is the tidyiest 24v conversion going
Old Oct 10, 2010 | 09:56 PM
m4tt274's Avatar
m4tt274
like this alot mate
Old Oct 10, 2010 | 09:59 PM
Zetecfiesta's Avatar
Zetecfiesta
awsome conversion!!
Old Oct 11, 2010 | 09:00 AM
chaffe's Avatar
chaffe
You using a jap syle mushroom air filter? liking the screamer pipe lol
Old Oct 11, 2010 | 09:45 PM
Damocos's Avatar
Damocos
Duuno yet, may do but other option is to run a filter behind the bumper and duct it up to the turbo. We will see.....
Old Oct 12, 2010 | 05:33 AM
chaffe's Avatar
chaffe
Looking good! any pics of the link pipe mate? would like to see someone elses take on things
Old Oct 12, 2010 | 06:09 AM
Damocos's Avatar
Damocos
Yeah, will post some more tonight
Old Oct 12, 2010 | 07:04 AM
chaffe's Avatar
chaffe
Cool, look forward to it! Does it run yet?
Old Oct 12, 2010 | 10:15 PM
Damocos's Avatar
Damocos
Oh yeah she runs, not well as its not had the basics done but we are playing with the laptop atm.......
Old Oct 13, 2010 | 05:25 AM
chaffe's Avatar
chaffe
Cool, keep the updates coming!
Old Oct 13, 2010 | 09:08 AM
katluke's Avatar
katluke
Love this type of thread,wish I had the skills and time to attempt something like this
Old Oct 13, 2010 | 01:18 PM
Damocos's Avatar
Damocos
Old Oct 13, 2010 | 01:27 PM
lead_foot's Avatar
lead_foot
is awesome
Cool as fuck mate.
The turbine housing looks like twice the size of the compressor housing.
Old Oct 14, 2010 | 01:09 PM
chaffe's Avatar
chaffe
lol, big turbos are ace, exhaust housing is soo wide cos its twinscroll
Old Oct 14, 2010 | 05:13 PM
turbo m's Avatar
turbo m
I just love this i enjoy reading about these home built motors.Keep the pics comming..
Old Apr 14, 2011 | 11:04 AM
boxer's Avatar
boxer
Hi new guy here love what you'be done full marks got me over a problem with injectors if all is well can't wait to see what power she makes mine ls still in Scorpio all the best mate
Old Apr 14, 2011 | 11:19 AM
Red16's Avatar
Red16
Cool project, nice to see you haven't just shoved a YB in it.
Old Apr 15, 2011 | 05:30 PM
Marcyg's Avatar
Marcyg
Nice one Damo. I was in another Sierra following this through Holland the other year, it went like the clappers before the turbo was fitted. Sounds lovely too. Can't wait to see it again
Old Apr 15, 2011 | 07:20 PM
JohnnyB's Avatar
JohnnyB
These go like fuck, 300bhp easy.
Old Aug 24, 2011 | 11:13 PM
BigErn's Avatar
BigErn
Old Aug 25, 2011 | 05:38 AM
chaffe's Avatar
chaffe
old thread this! is it finished yet? ive sold my turbo v6 now
Old Aug 26, 2011 | 04:11 PM
jim_robson's Avatar
jim_robson
This has been mapped now, made around 330bhp iirc.
Old Dec 22, 2015 | 02:16 PM
costina's Avatar
costina
Live long and prosper!!
Any more info on this?
Old Dec 23, 2015 | 03:38 PM
Willka's Avatar
Willka
Ford KA 1.7 Vct, soon...
Very cool project, does a twin scroll turbo actually effect performance? Ive heard about the benefits (quicker spolling etc), im surprised they aren't used more
