whats needed for 380bhp saph cos
hi peeps
currentley running a stage 1 set up on dark green injectors
on my 4x4 saph looking at upgrading the power to 380bhp can this be done on a 1k budget or will more money be required?
cheers
cheers
standard pistons etc are fine mate you will need at least a t34 turbo a good 500 style cooler injectors,044 fuel pump and a remap also good idea to check and upgrade brakes etc at this power level and cooling system if you intend to use the car in anger silicone hoses ali rad turbo cooler ali header tank all good upgrades and help to keep things reliable also worth running a low temp thermostat and upgrading fan wiring and possible fuel pump wiring aswell as tabs said trawl the classifieds on here as there is alot available seconhand good luck!!
Also good advice on some samco hoses and an uprated alloy rad but as you can get around the Ł250 mark back for your turbo and injectors i reckon you could do it..
cheers danny
155lee
Aug 14, 2015 11:21 AM
