S2 Gearbox
Old Oct 5, 2010 | 01:14 PM
bencossie's Avatar
bencossie
Default S2 Gearbox
Hi there im on the look out for a S2 gearbox but im in 2 minds wheter tio get mine rebuilt or buy secondhand. I have found one that does not have LSD could i take the LSD off my one and put it in the other one or would it not work. Also what is the benefits of have LSD
cheeRS
Ben
Old Oct 5, 2010 | 01:44 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Ben
Check this out
http://www.quantums.info/gearbox.htm
Old Oct 5, 2010 | 01:54 PM
bencossie's Avatar
bencossie
cheers mate
Old Oct 5, 2010 | 04:26 PM
mattseries2's Avatar
mattseries2
I have one forsale!
Old Oct 5, 2010 | 04:35 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Sorry to hi-jack this but while on the subject,is it possible to put a lsd in my diesel box,as i love the ratio's these give compared to the rs box.
Old Oct 5, 2010 | 04:36 PM
mattseries2
Im almost 100% sure you can mate! Im sure someone else will correct me if im wrong, or drop Karlos a PM he would know.
Old Oct 5, 2010 | 04:53 PM
essexRSTSouthend
I thought id double check.cheers mate.
Old Oct 5, 2010 | 09:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes the LSD is interchangeable between all BC boxs, bencossie the advantage is less wheelspin mate.
If buying second hand then either get a cheapo for Ł50 and take your chances or get one with a reciept for a recent rebuild and pay a little more.
Old Oct 6, 2010 | 07:24 AM
bencossie's Avatar
bencossie
yer i think ure right karlos cheers. i was told the ib5 diesel box is the best but i gather the lsd cant go into that
Old Oct 6, 2010 | 12:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes it can but no they are not the best, ALL IB5 box's are the same strength, they all use the same bearings, shafts, cogs, etc. just have differnet ratio's.
They are stronger than the BC box's because of bigger bearings and a more webbed casing preventing flex under torque.
Old Oct 6, 2010 | 12:55 PM
bencossie's Avatar
bencossie
ok cool well i finally got it you seem quite a knowledgable guy perhaps when weather aint shit i may bring it over or if you are ever over this way pop by
Old Oct 6, 2010 | 12:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate sounds good!
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
