T34 .63 Mar-m shaft 247
Old Oct 5, 2010 | 12:10 PM
Mr C's Avatar
Mr C
Default T34 .63 Mar-m shaft 247
Whats this worth? My T34 .63 exh housing, with a genuine Mar-m 247 shaft, quick release manifold and a 34mm restrictor, its done 500miles on my car since its rebuild and Im realistically not going to use the turbo to its full potential on track or road so was wondering- Whats it worth? who is interested? and is there a market for it right now?
Old Oct 5, 2010 | 02:55 PM
markk's Avatar
markk
my last one same spec as that went for just under Ł600 nearly four years ago.
Old Oct 5, 2010 | 03:25 PM
derekd's Avatar
derekd
around 5-600
Old Oct 5, 2010 | 04:51 PM
s1cab's Avatar
s1cab
how much you looking for this? who built it ? usuall 360 bearings etc? what does the restrictor do?
pics please?
thanks
Old Oct 5, 2010 | 10:25 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
pics
Old Oct 6, 2010 | 01:06 PM
paddyrs's Avatar
paddyrs
i mite be interested
Old Oct 7, 2010 | 05:22 PM
Mr C's Avatar
Mr C
I will try and get pics up again but photobucket isnt working for me again. I was hoping it was worth a bit more still but its hardly worth me swapping over to a std T34 .63 in as good condition as this one. What do they usually go for without the Mar-m core?
Old Oct 7, 2010 | 05:26 PM
Mr C's Avatar
Mr C
the restrictor limits the amount of air that can enter the turbo so caps the power, I still have it on so I have a way of fitting an air filter, you could run without it for full power or get it mapped with it on for big torque.
In use it actually drives very well with one on, linear in power delivery like an N/A I would like to see a power graph to compare as its more driveable with it on if not as much PSI
Old Oct 7, 2010 | 05:27 PM
s1cab's Avatar
s1cab
with a standard shaft usually between Ł300 and Ł450 depending on condition and spec.
Old Oct 8, 2010 | 10:23 PM
Mr C's Avatar
Mr C
One pic that works but this was just a "what's it worth" post
Old Oct 9, 2010 | 08:33 AM
s1cab's Avatar
s1cab
you gonna be selling this mate ?
Old Oct 11, 2010 | 10:00 AM
Mr C's Avatar
Mr C
Not if Ive got to spend Ł400 on a new T34 and only get Ł600 for this, this one will stay on
Thankyou for your replies
Old Oct 11, 2010 | 11:50 AM
s1cab's Avatar
s1cab
thanks for letting us know
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
