Esc cos bt boost
Old Oct 3, 2010 | 07:48 PM
C4 KCB's Avatar
C4 KCB
Default Esc cos bt boost
Just bought a bt escort cosworth. Car is standard. When driving the boost sometimes only goes to around 5-6psi then other times its fine but drops off. When at lower boost level it will sometimes stutter a bit. I have fitted another actuator and went ok to start but then problem came back. I am thinking along the lines of a map sensor or amal valve. Any ideas what could be causing the problem?
Kenny
Old Oct 3, 2010 | 07:58 PM
BIL N KEL's Avatar
BIL N KEL
sounds like amal valve could be playing up. if thats ok check you have 12v going to amal valve as this caused me no end of trouble
Billy
Old Oct 3, 2010 | 08:29 PM
THEDMAN's Avatar
THEDMAN
Polaris Grey by any chance?
Old Oct 3, 2010 | 08:34 PM
C4 KCB's Avatar
C4 KCB
Default .
Cheers will check the voltage tmrw, its weird tho as its fine sometimes then not.
Sure is darren
Old Oct 3, 2010 | 08:38 PM
fordrs2005's Avatar
fordrs2005
its fucked kenny ,since am a nice guy , al bail you out and give you your money back ,
Old Oct 4, 2010 | 08:10 PM
C4 KCB's Avatar
C4 KCB
Default .
lol im sure you would Gibby but il stick with it the now.
Anyone know the best place to get a new amal valve from?
Old Oct 4, 2010 | 08:37 PM
fordrs2005's Avatar
fordrs2005
post up on the wos site kenny , am sure somebody will have one or even give you a dhot of one to try to see it thats what it is
Old Oct 4, 2010 | 08:41 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
stop phrasing it and that drop is were it spikes be careful and get it set-up by a pro before u waste more money ,,,
good choice of car cant wait to get a real one
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
