Vibration (Zetec)
Old Jan 25, 2005 | 01:03 PM
Notorious_G's Avatar
Notorious_G
Default Vibration (Zetec)
hi
got a problem with me 2i 16v, when im traveling at motorway speeds im getting alot
of vibrations throught the S/wheel and gas pedal, anyone got any ideas??
ive had it tracked etc so it aint that, i also had it compression tested to see if it were
a sticky valve like my engines prone to but got the all clear
i notice its only when i press the gas pedal, could it be a knackered Injector, cams or sensor
any help would be good cheers
Old Jan 25, 2005 | 01:32 PM
AKRS1's Avatar
AKRS1
have u had your wheels balanced
Old Jan 26, 2005 | 03:07 PM
Notorious_G
hi
yes ive had the wheels balanced,
could it be a knackered alternator that is causing it??
Old Jan 26, 2005 | 03:18 PM
AKRS1's Avatar
AKRS1
i wouldnt have thought it would be a alternator maybe something to do with your driveshafts or even gearbox mounts. have a mechanic look at it cant charge you for just having a look at it
Old Jan 28, 2005 | 12:59 PM
Notorious_G
driveshafts
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
talon1
Sep 15, 2015 10:27 AM
