Push button start
Old Oct 2, 2010 | 08:11 PM
T666 FRS's Avatar
T666 FRS
Default Push button start
Hi guys,
has anyone got a diagram or can tell me how to wire in a push button start on my series 2 RS?
Looking to remove the whole ignition barrel setup eventually and will only be using it for a track car so no worries about the security side of things.
Cheers in advance
Old Oct 3, 2010 | 09:56 AM
If only used for the track then a "normal" switch panel thing might be a good bet, but otherwise it is very easy, using a heavy duty ON/OFF switch and a heavy duty momentary push button switch, I have a illuminated push button start switch to go in mine in red, but can get these in blue as well for around £8, these are illuminated and when wired to the oil pressure sender wire serves as a extra warning light for the oil light.
Just do a check on the ignition switch to see what wire is what in each position inc the start wire, then live in and out can be put either side on the main switch, then a live from the out of the main switch to the starter push button, so starter will only operate when main switch is on.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
fuzzy
Sep 4, 2015 10:11 PM
kevin36
Sep 2, 2015 06:24 PM
