Engine warning light on
Old Oct 2, 2010 | 05:17 PM
KAman's Avatar
KAman
Default Engine warning light on
2003 KA engine fault light on and a missfire when warm ive changed the
plugs and tryed to find the fault codes with the trip button had no luck
any ideas
thankyou
regards KAman
Old Oct 2, 2010 | 05:23 PM
Alvyn's Avatar
Alvyn
need to go and get the fault code diagnosed then IF nothing is obviously clearly hanging off or broken!
Old Oct 2, 2010 | 05:37 PM
martysmartie's Avatar
martysmartie
Have you tried resetting ECU to see if fault reappears? If not I would say possibly CPS.
Martin
Old Oct 3, 2010 | 07:39 AM
oldford's Avatar
oldford
Check for air leaks around inlet- and exhaust-manifold.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
