Newbie needs help with power steering
Old Oct 2, 2010 | 04:01 PM
fordfizzerowner's Avatar
fordfizzerowner
Default Newbie needs help with power steering
Hello everyone
I'm new to the boards - but not Fords!
I have a fiesta Mk3 ('95) Frascati with power steering, and recently the steering rack failed the MoT for leaking......well I bit the bullet and decided to change it rather than bodge with leak stopper etc - trouble is, when I come to refit the new rack, I can't get the return line out of the rack to fit and seal properly - the gland nut does up tight, but the hose going on on to the back stays loose - which I can see is going to leak fluid when I turn the engine on!
Question to anyone out there that knows, is there any type of seal which needs to go onto the rack before putting the line on????? I didnt see any come out of the old one - but I guess it could have got chewed up during removal?
Gary (a frustrated fizzer owner)
Old Oct 2, 2010 | 06:54 PM
Usually have seals on the lines on the rack, being loose when tightened would suggest also this is the case, there's most likely a slight recess where a o ring seal goes over the pipe part and sits in the rack threaded area.
Old Oct 3, 2010 | 10:32 AM
fordfizzerowner
Thanks tabetha - I got on the phone to ford parts at Stafford who said there is a teflon ring, I'm going to pick them up tomorrow - I just hope it does the job because the drive way is getting a nice puddle of fluid on it right now!!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
