focus rs mk1, problems
Old Oct 1, 2010 | 08:34 PM
RoyP's Avatar
RoyP
Default focus rs mk1, problems
hi all,
i have some problems with my rs,
is seems that when driving at a constant speed the car seems to misfire or something, its best noticeble between 2000 and 3000 rpm, what causes this,
it also seems that when accelerating at full throttle it doenst pull smoothly up to the shift light, and when you change gear i doesnt seem the pick up as it should, boost pressure doenst build up quickly enough it seems.
what could cause this? its quite enoying,
i already changed, spark plugs, ignition pack, and leads,
the car is fitted with stainless exhaust and bleufin, and has the original airbox, didnt drive well with a k&n filter.
hope someone can help
greetz
Old Oct 1, 2010 | 09:01 PM
frs2208's Avatar
frs2208
could be an air leak somewhere
the mis-fire between 2k and 3k rev's could be the 'cough' if your running the af map on the car
Old Oct 1, 2010 | 09:29 PM
RoyP's Avatar
RoyP
tought that the Af cough was around 5k?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
