Mk1 focus lx
Old Oct 1, 2010 | 08:32 PM
Wooddemon's Avatar
Wooddemon
Default Mk1 focus lx
Hi i have a v reg focus tddi lx, it doesn't have foglights but want to fit them, can it be done, is the wiring there somewhere to just plug them in? any help or suggestions would be much appricated,
also can a heated front windscreen be fitted??
Chris...
Old Oct 2, 2010 | 11:43 AM
martysmartie's Avatar
martysmartie
Yes the wiring is already there tapped up underneath onto the chassis leg IIRC, you just need a switch from a compatiable model I.E Zetec apart from that the jobs jobbed! Heated screen should also be easy to fit as it was avaliable if you got 'Climate pack' which also included heated washer jets, should think you just need loom, switch etc.
Martin
Old Oct 2, 2010 | 09:24 PM
Wooddemon's Avatar
Wooddemon
Great thats what i wanted to hear, so are the connectors already on the wiring to plug into the fog lights? and all i need is the lights control switch in the car with the fog option on it??
How do you mean by the switch/loom for fitting heated front screen? sorry i'm quiet a novice on these things, i had a 1.8 zetec with all this but part ex'd it for a desiel for cheeper running not thinking about the benifits of the climate pack in the colder weather,
Thanks,
Chris..
Old Oct 3, 2010 | 11:24 AM
martysmartie
The connectors are also there yes, taped up for each light onto each chassis leg, all you need is a switch as yours won't have a position for front fogs and the lights themselves of course.
I should imagine you need the wiring loom and switch for the front screen and of course a whole new heated front screen to be fitted as well. This is not part of the car loom and so should just plug in.
Martin
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
massivewangers
30
Oct 1, 2015 07:40 PM
richierich1986
Sep 18, 2015 03:29 PM
JamboRS
28
Sep 14, 2015 09:02 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
