Dyno disappointments
Old Oct 1, 2010 | 10:58 AM
omegadesignsolutions's Avatar
Default Dyno disappointments
Hi There,
Just come from the dyno expecting 500 BHP but unfortunately i was a little disapointed, does anyone have any ideas as to why we aren't making any more real power after 4750 rpm??
Cheers Matt
Old Oct 1, 2010 | 11:01 AM
chaffe's Avatar
chaffe
Turbocharging Technician
goes quite rich towards the end mate, also what turbo you running?
rubinsbin's Avatar
rubinsbin
ide have asked the dyno operator !!!!!!! is he the guy you paid??
he has the info in front of him-----
Old Oct 1, 2010 | 11:02 AM
chaffe's Avatar
chaffe
Also just noticed 13.25:1 at 5000rpm injectors maxed out maybe? Meant to say though good power all the same
Old Oct 1, 2010 | 11:19 AM
hi,
bit of background....
GT30- 2WD MANIFOLD
SIEMENS 850 INJECTORS
RS500 INTERCOOLER
EMERALD K6 MAPPED BY YOURS TRULY
4WD INDUCTION MANIFOLD WITH 10 MM SPACER
8TO 1 CR
3" MONGOOSE EXHAUST
dyno was just used for power run therefore no input from opperator
cheers
matt
Old Oct 1, 2010 | 11:21 AM
chaffe's Avatar
chaffe
sounds like the car is well up to the job mate!, not the fuel pump or filter that is causing it the lean off is it? what is the duty cycle on the injectors at 5k on full boost? good on ya for mapping it yourself at that power level
Old Oct 1, 2010 | 11:48 AM
the way i look at it is that it is rich at the top end???
Old Oct 1, 2010 | 11:51 AM
chaffe's Avatar
chaffe
yeah it sure is, would benifit from leaning off a touch, but at peak torque it is dangerously lean mate.
Old Oct 1, 2010 | 11:56 AM
chaffe's Avatar
chaffe
you can see where it blips rich and lean (in the first graph) the power mimics it exactly, either going up or down. But as it gets richer and richer past 5k, the power is tailing off quicker than i would expect it to. Def needs a touch more fuel as it comes on boost and at peak torque, but im sure you will have the laptop out later
Old Oct 1, 2010 | 12:22 PM
Miller 3's Avatar
Miller 3
The afr is all over the place!
could do with holding more boost top end too.
Old Oct 1, 2010 | 12:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by omegadesignsolutions
hi,
GT30- 2WD MANIFOLD
RS500 INTERCOOLER
8TO 1 CR
3" MONGOOSE EXHAUST
cheers
matt
If this is totally built and mapped by you, why are you asking us?
Looks to me like it runs short of spark lead and runs too rich, but thats a guess at a piece of paper without knowing engine specifics or IAC temps during the run.
Is the turbo big enough for your expectations?
Old Oct 1, 2010 | 01:35 PM
what does spark lead mean?advance?
what i find suprising is the power map looks quite good to 5000 rpm and then it hits
the "wall",i was expecting the bhp to climb with a similar curve-to 7000 rpm???both maps show to me a similar trace-what is the correlation??
thanks for the comments so far...
matt
Old Oct 1, 2010 | 01:43 PM
DazC's Avatar
DazC
Cams?
Head ports?
AFR all over the place?
What does the ignition table look like and what air temperatures what it running on boost?
Old Oct 1, 2010 | 02:31 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Surely if your mapping your expensive cossie yourself then you should know what all the different parameters are?? No disrespect but it seems a bit stupid to not know that lot yet risk melting your engine!
Old Oct 1, 2010 | 03:29 PM
the cams are standard cosworth with 8.5 mm of lift
regards porting- stage 1-polished,blended etc.standard valves and seats
I will look at the ignition map and post details later...
cheers
Old Oct 1, 2010 | 05:46 PM
Surely it would just save hassle and a potential huge amount of money long term to pay someone to map it, mapping is a huge amount less than a rebuild, Ł280 at Emerald for instance, but peace of mind, and an even better drive back after mapping!!
Had my injectors cleaned there yesterday 1 had a odd spray pattern just like a steam instead of a nice fan, ok last year seems they don't take to a bit of inactivity too well.
Old Oct 1, 2010 | 06:34 PM
Mark Shead's Avatar
Mark Shead
cheers
That should be power at the hubs so I dont think the powers that bad, You wont get much more with your head and cam spec,
I would take a look at your mapping skills with a afr graph like that.
Mark
tankybaby66
Feb 6, 2016 02:24 PM
Chas
Sep 21, 2015 08:57 PM
bigluke200
14
Sep 2, 2015 10:35 PM
yawiejon
15
Aug 9, 2015 06:36 PM
RIB1122
Aug 3, 2015 09:20 AM
