4x4-no drive at front wheels
Old Sep 30, 2010 | 02:36 PM
sir nose's Avatar
sir nose
Default 4x4-no drive at front wheels
i found out while on a rolling road today that my saff 4x4 is now 2wd,theres no drive to the front wheels.
whats causing this?
i guess the centre diff but how can i diagnose it? and how big a job is it to change?
thanks
Old Sep 30, 2010 | 02:50 PM
phil_focus's Avatar
phil_focus
i know this may sound a stupid question but has it still got all the 4x4 stuff? many get converted to rwd. or have the front shafts fallen out at some point??
Old Sep 30, 2010 | 02:59 PM
The Youth.'s Avatar
The Youth.
viscous coupling centre diff has failed, need replacing/fixing or new gearbox..
steve
Old Sep 30, 2010 | 03:16 PM
sir nose's Avatar
sir nose
steve
is it much of a job to change the centre viscous coupling?are uprated ones available?
Old Sep 30, 2010 | 03:47 PM
James @ M Developments.'s Avatar
you can get "pumped up" versions from the likes of bara motorsport
Old Sep 30, 2010 | 07:04 PM
Make it RWD, ie REAL wheel drive!!
ps someones phoning me friday night who has a 4wd breaking with a refurbed box.
Old Sep 30, 2010 | 08:09 PM
sir nose's Avatar
sir nose
ive searched for bara stuff on the web but not found nothing outside this forum.anyone have contact details for bara motorsport.
anyone ever changed a viscous coupling?i'd like to know if its do'able.
just spoke to a fella on the phone who has a s/hand transfer box.whats it worth?any idea's im thinking maybe offer him £50
Old Oct 1, 2010 | 07:41 AM
sir nose's Avatar
sir nose
Q,if i lift the vehicle on a 2 post lift so all the wheels are off the ground and spin a rear wheel should the fronts move?
Old Oct 1, 2010 | 07:48 AM
chaffe's Avatar
chaffe
Turbocharging Technician
I stripped and re built an mt75 box mate, you have to take the rear casing off to do the coupling, its fairly major strip down and re-build, but nothing too technical. I had a realy good viscous coupling up until last week when a mate took it away with some other spares! i could see if he still has it?
Old Oct 1, 2010 | 04:30 PM
sir nose's Avatar
sir nose
thanks but i think ive found a transfer box,can it be changed in situ?
Old Oct 1, 2010 | 06:36 PM
chaffe's Avatar
chaffe
ill have alook at my casings in the shed if it ever stops raining, and let you know
Old Oct 1, 2010 | 08:00 PM
forevaford's Avatar
forevaford
if its now rwd then why are u moaning??? i wish my 4x4 did that on its own. i had to convert it insted.
lol
Old Oct 1, 2010 | 09:01 PM
sir nose's Avatar
sir nose
ive just travelled over 100 miles to discover what was thought to be a transfer box is a front diff.
gonna attempt to strip it out in situ tomorrow.
Old Oct 1, 2010 | 09:03 PM
graham c's Avatar
graham c
box is easy
Old Oct 2, 2010 | 04:06 PM
sir nose's Avatar
sir nose
is there meant to be oil or something inside the vc? mines dry as a bone even a little rusty.
Old Oct 2, 2010 | 06:51 PM
YES, this is where the word viscous comes from, a HYDRODYNAMIC friction between two surfaces to transmit a appropriate designed in amount of torque from one surface to another, usually using high viscosity silicone fluids.
Old Oct 8, 2010 | 05:42 PM
sir nose's Avatar
sir nose
ive got another vc i want to put it back together tomorrow but ive damaged the steel breather pipe inside the transfer box section.can i leave this part out?
Old Oct 8, 2010 | 07:13 PM
cossie daz's Avatar
cossie daz
mine had done this too
was at TOTD and front wheels werent spinning
it viscous coupling and cts do them for around £250 and about £50 fitting just have to take your box to them
even as VC has gone and rwd ,mine seems to be 4wd at times on the road
its not just a case of it being rwd now ,if you want it rwd you will have to convert it using 2wd parts .
hope this helps
my escort cossie done this and im thinking of going 2wd conversion
Old Oct 8, 2010 | 09:09 PM
sir nose's Avatar
sir nose
anyone got a knackered mt75 in bits?
original
Apr 28, 2026 05:20 PM
Chas
Sep 21, 2015 08:57 PM
C2 MAK
Aug 20, 2015 09:46 PM
cossynut2
Aug 19, 2015 11:29 AM
muz
Aug 1, 2015 06:48 AM
