how do i replace heater control cable
Old Sep 29, 2010 | 09:25 PM
mondeo manx's Avatar
mondeo manx
Default how do i replace heater control cable
no heat in mk2 mondeo glx estate suspect cable may be broken do i have to remove dash to replace it,thanks
Old Sep 30, 2010 | 07:10 PM
No not complete dash, most likely if there is no cable movement from the heat selector is that is has detached, never seen one break, jesus they are hard enough to cut when needing to, they're not unknown for detaching, you can laways take off the panel at the side that covers the area and goes rearwards towards the seat and move the flap manually this will straight away get you full heat and tell you what the problem is, 99.9% one end has popped off at the cable.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
Flatlinedan
Sep 18, 2015 12:41 PM
routemaster
Sep 7, 2015 05:27 PM
