Can my Omex 710 still be a slut?
Old Sep 28, 2010 | 11:19 PM
neilnewboy's Avatar
neilnewboy
Default Can my Omex 710 still be a slut?
i have a xflow and a cologne V6 lump both becoming EFI
can i have, say a Omex 710 to share between the 2 cars with a ECU re-flash depending on which one i will be running for 6months, would save a fare bit just sitting doing nothing?
Old Sep 29, 2010 | 07:37 AM
Ryan's Avatar
Ryan
yes easy to do, ecu might even be able to have 2 different maps on the same ecu, for different configs.
if not you'll just have to upload the map for the relevant car to the ecu.
Old Sep 29, 2010 | 07:39 AM
Jim Galbally's Avatar
Jim Galbally
just remember to buy 2 lots of ECU wiring inc. connectors and put the thing somewhere easy to get at
Old Sep 29, 2010 | 02:31 PM
neilnewboy's Avatar
neilnewboy
excellent, cheers for the replies
Old Sep 29, 2010 | 02:35 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yes of course you can, no problem at all.
Old Jan 17, 2012 | 09:13 PM
neilnewboy's Avatar
neilnewboy
i picked up a 710 setup for a v8 with cop's(mustang) i want to run the v8 still and also a v6 efi cologne lump.
The ecu has had the internal drivers removed and 2 external bosch ignition module included in the package to run the COPs as wasted spark.
My question is what do i need to do/purchase/wire in so that the 710 in its current setup can be extended to run the v6 efi cologne lump as well? Will the signals to a COP be the same as to that of a coilpack?
Thanks in advance
Old Jan 17, 2012 | 10:21 PM
Chip's Avatar
Chip
depends what coilpack and what cop, some are triggered by just a signal level current and some are actually fired.
Who removed the drivers? I'd talk to them as a starting point.
Old Jan 18, 2012 | 10:21 AM
neilnewboy's Avatar
neilnewboy
Thanks Chip, it was Omex who removed the internal drivers, have already been in touch with Andy and the reply this morning was
It sounds to me like the best setup for you would be to leave the ECU as it is and run an amplified coil pack
directly from the ECU.
I dont expect for Andy to give me a lesson in ECU ignition driver technologies and dont really expect Omex as a company to support me when the Omex 710 purchased for a V8 does exactly what its meant to do.... this V6 request is extra
Are there 2 types of coilpacks available, one amplified one type not?
I assume a lot of this depends on the ouptut setting on the ECU as to what coilpack is suitable?
Old Jan 18, 2012 | 10:28 AM
Chip's Avatar
Chip
Yes some coilpacks have an internal amp and others dont.
Ones which dont can be run with external amps normally so they then appear to the ecu as if they did have.
Old Jan 18, 2012 | 10:37 AM
neilnewboy's Avatar
neilnewboy
Alrite! Nice one Chip....
I will get on and do some research for suitable V6 coilpacks.
iBall from powers is back this weekend so i will try and get him in on the loop for this.
U at the next Middx RSOC meet?
Old Jan 18, 2012 | 10:40 AM
Chip's Avatar
Chip
Not sure yet mate a got a lot on in the evenings at the moment.
You could always use two 4 cylinder coilpacks and simply not run leads to two of the outputs on one pack.
good thing about that, is you have a spare coil if one goes down, quick bit of roadside bodgery to swap the leads and input wires around and you'd be back firing on six again
Old Jan 18, 2012 | 10:57 AM
neilnewboy's Avatar
neilnewboy
coilpack redundancy.... nice!!
Coolio if i c u there i'll say hello
Old Jan 18, 2012 | 01:13 PM
Jim Galbally
v6 granada and mondeos use EECIV and have the ford coilpacks. dunno if theyre suitable or not tho just bear them in mind as a possibility
Old Jan 19, 2012 | 08:51 PM
neilnewboy's Avatar
neilnewboy
thanks Jim will look into those, Andy from Omex has replied, he is a very help fella! He is going to sort out a base map for the V6 with an amplified coil pack so i dont have to do anything to the ecu just swap from car to car and switch the map!!
anyways here's the V6 cortina......
here the V8s destination........
Old Jan 19, 2012 | 08:54 PM
botters's Avatar
botters
competant bodger
niiiicccceeee get a build thread up on those motors mate, that escort van will be immense with a v8 in
Old Jan 19, 2012 | 09:14 PM
neilnewboy's Avatar
neilnewboy
will put one together over the weekend...... something to wet the appetite thou!
dombanks
Sep 21, 2015 08:38 PM
jay030787
Sep 18, 2015 07:34 PM
Tank Mike
Sep 14, 2015 03:56 PM
ekjim
Aug 17, 2015 08:57 PM
turbobill
Aug 9, 2015 05:21 PM
