Rev counter
Old Sep 26, 2010 | 07:31 PM
bolanjames's Avatar
bolanjames
Unhappy Rev counter
Hello everyone. Have a 98 escort 1.4 without rev counter. Bought a set of dials with rev counter and was told to wire it from pin 8 on blue plug to pin 4 on ecu. Done this but nothing. Am i doing it right for a 1.4? Any help gratefully received. Thanks.
Old Sep 26, 2010 | 08:16 PM
Austin101's Avatar
Austin101
Your talkin sh** now
I may be worng here but if you run a wire from the rev clock to the nagtive on the coil it should work.Its old school.
Old Sep 27, 2010 | 11:17 AM
Not certain but would have thought that a 98 escort would be plug and play, as in same loom used on both tacho and non tacho ones ?
Old Sep 27, 2010 | 03:46 PM
bolanjames's Avatar
bolanjames
I thought that to. But its not much to my dismay.
Old Oct 11, 2010 | 01:53 PM
bolanjames's Avatar
bolanjames
Unhappy
Still cant get this to work.was told to wire it to edis module but there isnt one and was told pin 20 AND pin 2 on ecu. Which is it anybody know?
Old Oct 11, 2010 | 03:21 PM
You need to identify the three wires going to the tacho on the rear of the clock set , these will be a live(ignition) a earth and a coil negative, from this you should be able to determine which wire is which and wire it.
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
