2wd Steering Column coupling.
Old Sep 24, 2010 | 09:45 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Default 2wd Steering Column coupling.
Anyone know where you can buy one.
Cheers Rod
Old Sep 24, 2010 | 09:52 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
tried the usual cossie breakers on here? Egay?
Old Sep 24, 2010 | 09:57 PM
Karl 3dr's Avatar
Karl 3dr
The rubber flexible one?
Very difficult to find as i've found out recently
I would have thought this would fit as long as its the same size?
http://cgi.ebay.co.uk/Ford-Cortina-E...item3a5e322ed7
Old Sep 25, 2010 | 07:06 AM
dojj's Avatar
dojj
Resident Wrestling Legend
I thought you could use a land rover coupling?
Can you not get one made up or are you just after the rubber bit in the middle?
If it's the rubber bit, you can try replacing it with a metal disc, but that makes thing a bit hairy as there is no give in the steeringbwhen you hit a small bump in he road so not really recommended.
If you are struggling for a full one the granadas also used the same parts so you may be able to use that one, but it's got to be from a power steering car as the non ps columns have a different set up.
Old Sep 25, 2010 | 09:39 AM
www.southwalesprops.co.uk
do these, if you want to keep it std type, think I'm going to go solid joints on mine.
Old Sep 25, 2010 | 10:09 AM
Alvyn's Avatar
Alvyn
Rod, if you or know any one handy with a welder get a 4x4 one cut it down to size and weld it up job done!
Old Sep 25, 2010 | 11:26 AM
dojj's Avatar
dojj
the 4x4 ones much better but i think it's probably not an option to chop it down, might be able to chop it down and then sleeve it and weld it and stuff to make sure it won't come apart, just to be on the safe side, but they are £110 new, if you can get them
Old Sep 25, 2010 | 11:36 AM
fordsportjay's Avatar
fordsportjay
im sure ive got 2 very good ones at work,in fact i think one still has the part sticker on it.
ill have a look either later today or monday
Old Sep 25, 2010 | 11:52 AM
Alvyn's Avatar
Alvyn
thought ANY one who knows about welding would of done it this ways tbh
Old Sep 25, 2010 | 03:00 PM
dojj's Avatar
dojj
yuo'd be surprised
Old Sep 25, 2010 | 03:16 PM
JonnyBravo's Avatar
JonnyBravo
BUrton Power do them, my mates 3 door one was burnt to fook !
Old Sep 25, 2010 | 03:22 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Thanks
Old Sep 25, 2010 | 04:46 PM
Alvyn's Avatar
Alvyn
that's the least you can suffer when you run without a proper heat sheild in place tbh!
Old Sep 27, 2010 | 06:12 PM
MAD Ade's Avatar
MAD Ade
This what I had done with mine about twelve years ago, still as good as new
Cheers,
Ade.
Old Oct 7, 2010 | 09:09 AM
Alvyn's Avatar
Alvyn
Default one I done yesterday
Old Oct 7, 2010 | 05:19 PM
DazC's Avatar
DazC
Alvyn,
Have you got any penetration into the lower UJ? It looks like all the weld is on the shaft and that there is hardly any penetration into the UJ at all!
Old Oct 7, 2010 | 06:34 PM
focusv8's Avatar
focusv8
Welded steering..Ayrton Senna,,Enough said.
Old Oct 7, 2010 | 07:05 PM
155lee's Avatar
155lee
when i did mine last year i bought 1 gen ford 1 off ebay for a mk2 escort.was identical,grind off the rivets then bolt the new 1 up.sorted.
Old Oct 7, 2010 | 07:13 PM
philram's Avatar
philram
Mulechild
i replaced the rubber with alloy..
Old Oct 7, 2010 | 07:17 PM
Sonic Boom's Avatar
Sonic Boom
Me too:
Rich
Old Oct 7, 2010 | 11:23 PM
stevieturbo's Avatar
stevieturbo
C**t
Mines been welded much worse than that for 7 years now. No problems there. In fact...if you really knew what mine was made up from to get the triangular bit right ..... might be shocked lol.
As for the rubber coupling. Most motor factors used to sell replacements for these years ago. Although they were a nightmare to fit as they used bolts instead of rivets.
Old Oct 8, 2010 | 07:04 AM
Mr RS500's Avatar
Mr RS500
Do you get any vibration throught the steering when you use the alloy items ??
anyone want to make me some ( if there isnt a vibration problem lol ) as i have a box full of them with buggered rubber joints that i could fix and sell
Old Oct 8, 2010 | 07:09 AM
JonnyBravo's Avatar
JonnyBravo
Have you ever seen the Lifeline quick release wheel hubs
I can't see why the alloy ones being made would cause vibration if the 4x4's only used a universal type joint ?
Old Oct 8, 2010 | 08:05 AM
Mr RS500's Avatar
Mr RS500
Thge 4x4 items have a rubber liner bonded in them , they are not solid
Old Oct 8, 2010 | 08:37 AM
JonnyBravo's Avatar
JonnyBravo
You learn something new everyday.
Old Oct 8, 2010 | 10:02 AM
Sonic Boom's Avatar
Sonic Boom
I'm on coilovers, collins engine mounts, solid rack mounts and polybushed all round anyway so it didn't make any difference to me, no constant vibrating through the wheel.
I can get you one made up and try it on a standard car so see how it feels if you like Paul?
Cheers Rich
Old Oct 8, 2010 | 04:18 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Im sure all this ins & outs of Cossie steering columns is great for the anoraks but has anyone actually got a standard one I can purchase .
Old Oct 8, 2010 | 04:33 PM
cozmeister's Avatar
cozmeister
More boost Igor!
There's nothing like getting back on topic. I resorted to ebay when mine fell to bits about 2 years ago (wobbly was an understatement!). Got lucky and found a brand new one, in box for a tenner.
Is this any use: http://cgi.ebay.co.uk/Ford-Sierra-Gr...d#ht_585wt_912
Or this:
http://cgi.ebay.co.uk/Steering-Coupl...c#ht_614wt_912
Old Oct 8, 2010 | 04:35 PM
TimC's Avatar
TimC
Rod, ever thought about posting in the wanted section, you know, like your supposed to.
Old Oct 8, 2010 | 04:41 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
When I was under 65 that would have sounded sensible .
Old Oct 8, 2010 | 06:20 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Rod, I have a spare one that has had a replacement bush fitted that you coud use until you get yours sorted if thats any help?
As to solid mounting them I was going to do this(well get chris @cdfto make it) but had a few people say it would cause problems
https://passionford.com/forum/genera...on-cossys.html
Old Oct 8, 2010 | 07:04 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Mine is actually not bad, but it show just a tad of wear. Only needs replaceing because we take no chances on a Topspeed run. Mark pointed it out on a full inspection, it will have a second nut/bolt inspection at XSport & they may just point it out if its not replaced.
Old Oct 8, 2010 | 08:00 PM
Mr RS500's Avatar
Mr RS500
Cheers Rich
How much rich ?
Paul
Old Oct 8, 2010 | 09:55 PM
STUCOS's Avatar
STUCOS
Have a mint on rod,but dont know what it,s worth
cheeRS stu
Old Oct 8, 2010 | 11:00 PM
Sonic Boom's Avatar
Sonic Boom
How much rich ?
Paul
I'll send you one FOC mate pm us your address.
Rich
tankybaby66
Feb 6, 2016 02:24 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
