anyone do a silent running fuel pump that will flow 400bhp
Old Sep 22, 2010 | 09:03 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default anyone do a silent running fuel pump that will flow 400bhp
iv bought a car and the it has a 044 fuel pump under the middle of the car but its soo loud even when you in the car its terrible its not faulty as its been replaced with a new one and does the same. it is mounted directly to the underside on metal with no rubber mounts so that might be causing a bit of noise.
Can you get silent running aftermarket pumps if so what ones.
thanks
Old Sep 22, 2010 | 09:09 PM
Mark Shead's Avatar
Mark Shead
Rubber mount it and keep a eye on fuel pipe routing and how the pipe is held to the body.
Mark
Old Sep 22, 2010 | 09:18 PM
Roosie's Avatar
Roosie
would that be a reason why its making so much noise do you think?
Old Sep 22, 2010 | 09:20 PM
botters's Avatar
botters
competant bodger
i would have thought it would be making it a lot louder as it will be resonating through the car it probably wont do the pump much good being solid mounted either
Old Sep 22, 2010 | 09:23 PM
Mark Shead's Avatar
Mark Shead
Correct
Mark
Chip's Avatar
Chip
*** Sierra RS Custard ***
044 are fairly quite really providing they have a good gravity fed to them and are mounted on rubber, cant really hear mine.
Old Sep 22, 2010 | 09:49 PM
stevieturbo's Avatar
stevieturbo
C**t
I can hear my 044's.......until I start the engine lol
Old Sep 23, 2010 | 07:55 AM
Ratty's Avatar
Ratty
I can't hear my 044.......
Over the noise of the 2 Facet lift pumps that is
Old Sep 23, 2010 | 10:06 PM
Roosie's Avatar
Roosie
here is pic of pump it sits upright is this a problem?
Old Sep 23, 2010 | 10:11 PM
Roosie's Avatar
Roosie
and here is a small vid
Old Sep 23, 2010 | 10:15 PM
stevieturbo
C**t
As long as it is gravity fed ( or pump fed ) with a good unrestricted supply of fuel it wont really matter how it is mounted.
But I would never solid mount a pump
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
