Will turbo be ok, as leavng car off the road for 6 months
Old Sep 21, 2010 | 05:43 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default Will turbo be ok, as leavng car off the road for 6 months
as above, leaving the S2 off the road for the winter as i do abit of a tidy up its got a cover on it etc, just wondering if the turbo will be ok?
Old Sep 21, 2010 | 05:49 PM
Jim Galbally's Avatar
Jim Galbally
yes
Old Sep 21, 2010 | 05:53 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Ok thanks, just asking because someone told me, it will seize, which i found hard to believe
Old Sep 21, 2010 | 06:14 PM
StephenC's Avatar
StephenC
..BS Motorsport..
what about 6 years?
Old Sep 21, 2010 | 07:00 PM
dojj's Avatar
dojj
Resident Wrestling Legend
just oil them before you fire it up again
Old Sep 21, 2010 | 07:04 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
it'll be fine. My cosworth was dry stored for 17 years and it has been perfectly fine ever since. When you first start it up just let it run for a little bit
Old Sep 21, 2010 | 07:13 PM
phil_focus's Avatar
phil_focus
will be perfectly fine but when you start it up again i'd pull the plugs out (might be a little ott i admit) and crank it over to get oil pressure and oil reaching everywhere in the engine and turbo. then plugs back in and fire her up!
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
Archiejay
Aug 12, 2015 12:07 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
Adam-M
22
Aug 10, 2015 10:46 AM
