mondeo bonnet question
Old Sep 20, 2010 | 06:27 PM
turbolee's Avatar
turbolee
Default mondeo bonnet question
i cant open the bonnet on my 51 plate monedo diesel the key wont open itany other way to open it with out key thanks
Old Sep 20, 2010 | 06:34 PM
little bram's Avatar
little bram
no mate you will have to drill the lock. try spraying wd40 in the lock barrel before drilling it tho
lee
Old Sep 20, 2010 | 06:41 PM
Fiddy's Avatar
Fiddy
my old one used to play up from time to time, try pushing the key and wiggeling etc, before you resort to drilling it
Old Sep 20, 2010 | 06:45 PM
RS500/364's Avatar
RS500/364
Wrong
drill out the plastic behind the ford badge
Then the two flat sheared off bolts on ether side of the lock need to be drill out
Then remove the lock and replace when done with standard bolts !
Old Sep 20, 2010 | 08:05 PM
turbolee's Avatar
turbolee
thanks for the advice
Old Sep 20, 2010 | 08:48 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you are careful you won't need to replace anything other than the lock the badge will cover any holes you make
also, while you are at it, check to see if the plastic actuator is platic or metal as this is the bit you need ot change
Fiddy
21
Sep 29, 2015 06:10 PM
Brickhouse
Sep 21, 2015 04:31 PM
Brickhouse
Sep 20, 2015 11:47 AM
Chopshop85
Sep 12, 2015 06:42 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
