Auxiliary air valve
Old Sep 20, 2010 | 12:01 AM
Si74's Avatar
Si74
Default Auxiliary air valve
Tried this long winded in the RS turbo section so
simples:
Tried 3 different ones now, pointless exercise since there's no volts
going to them:
a) does the thinner red/black feed from the fuel pump relay go direct
to the aav - have continuity but 0.11v? Assuming its not a 25 amp feed
so where does it get reduced.. is there possibly a 'thingy' to take it to 10?
b) if I stick the damn things direct to a 12v battery, they should close?
seems simpler than crushing a solid plastic pipe on a car that barely runs
anyway
ps brown KE relay in fuse box - 87 pin 1 ecu, 85 ground, 86 .. 10 amps
but to what?
Tuesday I start tearing the loom apart, Thursday gets broken for expensive
scrap
Old Sep 22, 2010 | 11:28 PM
Si74's Avatar
Si74
No takers,
even simplers..
Brown KE relay in fuse box...
should this show continuity between pins 86 & 87 when pulled from the car??
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
