Ford Escort MK4 project
Old Sep 19, 2010 | 01:54 PM
ESCORT XR3i's Avatar
ESCORT XR3i
Default Ford Escort MK4 project
This is my project Ford Escort MK4 here is a video of project
My next project is install turbo a
nd remapping ECU
http://www.youtube.com/watch?v=f7gTkH7RbyQ
Old Sep 20, 2010 | 08:54 AM
ESCORT XR3i
Here is some very old pictures
Old Sep 22, 2010 | 11:30 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Dobar dan, mate! Imas odlicno vozilo!
Whereabouts in BiH are you? Good luck with the turbo conversion.
Old Sep 23, 2010 | 09:24 AM
jonny s2's Avatar
jonny s2
looks good mate
Old Sep 23, 2010 | 09:34 AM
ESCORT XR3i
Dobar dan i tebe mate ! Neko da prica Bosanski je pravo cudo
I live in Bihać (Bihach) near the Croatian border I don't know about turbo conversion, because is cheaper to buy 2.0 16V and install what do you think??? who 2.0 1.6V or 1.8 16V can install on my gearbox?
@jonny s2 thanks mate
Old Sep 23, 2010 | 10:22 AM
user 7082039239
I learned some by listening to Ekrem Jevric...
I'm not an expert regarding engine swaps but I would imagine that going for a Zetec conversion is by far the easiest thing to do. Especially since parts will be much easier to get hold of.
You've got the EFI version of the CVH, right? So if you use an early Zetec from the Escort Mk5 or Fiesta XR2i/RS1800 you should even be able to keep most of your engine loom, sensors, etc.
Old Sep 23, 2010 | 01:37 PM
ESCORT XR3i
I learned some by listening to Ekrem Jevric kralj si najjaci si
EFI I have only intake manifold and injectors from mk5, all installation,sensors, air flow sensor and ECU are from Opel ascona 1.8 (85kW) Everything is great, start nice, go nice, and performance are the same like on old K-jetronic, but I want something with more HP
"So if you use an early Zetec from the Escort Mk5 or Fiesta XR2i/RS1800"
Is that Zetec engine 1.8 16V or 2.0 16V??? And how much power produce??? I don't know can I install that Zezec engine on my gearbox???
sorry for my english, I do not speak well
Old Sep 23, 2010 | 02:06 PM
user 7082039239
Aha, that is some nice cross-engineering there!
The gearbox should bolt straight on to any old Zetec (starter motor at the front of the engine), but there are other things you might have to modify, two of them being alternator bracket and gearbox/engine mount, if I remember correctly. Just search the forum here, it has been done loads of times.
That Escort/Fiesta engine I meant is a 1.8 16V with 130 bhp. The normal 1.8 from the Mondeo has 115 bhp. You could also go for the 2.0 16V (136 bhp) from the Mondeo. This will have more torque but will be less revvy because it's the same bore as the 1.8, only stroke is longer.
Old Sep 23, 2010 | 03:40 PM
ESCORT XR3i
Thanks mate! I will start searching the engine new project hehehee
Old Sep 23, 2010 | 03:43 PM
Spoony.'s Avatar
Spoony.
Old Sep 23, 2010 | 03:57 PM
user 7082039239
BTW, are those seats from an R5 GT Turbo?
Old Sep 23, 2010 | 04:00 PM
ESCORT XR3i
nop from Renault 19 1.8 16V lack of them is that they can't overlap but I don't need that because I will install rollcage behind
Old Sep 23, 2010 | 04:02 PM
user 7082039239
nop From Renault 19 1.8 16V
Ah Ok, still funny as someone on here has put RS Turbo seats in his Renault R5...
Old Sep 23, 2010 | 04:14 PM
ESCORT XR3i
I couldn't find rs turbo seats so I buy seats from renault 19
Old Sep 24, 2010 | 08:47 PM
XR3iMk4Cab's Avatar
XR3iMk4Cab
odlično stanje
Old Sep 25, 2010 | 03:45 PM
ESCORT XR3i
@XR3iMk4Cab hvala drug Jeli znas pricati "naški"? hehehe
Old Nov 7, 2010 | 03:47 PM
ESCORT XR3i
New video of acceleration
http://www.youtube.com/watch?v=4NIuaKbXHto
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
A.t.p
Aug 15, 2015 11:37 AM
