clutch cable
any tips on refitting the clutch cable on a 4x4 3 door?
ive just had the engine and box out and cant seem to pull it far enough to get it over the release arm do i need to reset the clutch ratchet or owt?
i remember when i took it off it pulled quite violently out of my hand
ive just taken engine and box out of my 3dr last weekend and remember having a struggle to get my clutch cable off,try to lever back the clutch release arm as far back as it will go and use a pair of pliers to put the cable back into its slot in the arm.
to be fair to me graham i had just manhandled the engine box and subframe in on my own with no crane was pretty tired and didnt even attempt anything in the car! i just gave one quick pull on the cable before i had to go home and thought i would ask before going back today even tho i would have sorted it anyway
then just a case of lowering the car over it and hoping the subframe boltholes lined up which thankfully they did first time
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
muz
Sep 30, 2015 08:29 AM
