cossie engine bay clips
Im just doing a bit of a resto on the saph. Ive just finished painting the bay and im after the finis codes to replace the wiring loom clips, there is 3 different types i can see, your usual loom clip that goes along the inner wing, then there is the type where you sit the wiring in the clip then pull the ladder type tab over and it locks in (can also be found under you plastic sill strips in the car), then there the round type, 1 behind each healight wiper, holds the round type plugs in place ? and they also hold the abs round plugs on the front chassis rails where they come through from the inner wheel arch ?, any help would be apprciated.
Most(if not all) of these are available from www.bresco.com
track.focus'd
Aug 12, 2015 05:53 PM
