Red Top Battery
Old Sep 17, 2010 | 03:07 PM
focus 4x4's Avatar
focus 4x4
Default Red Top Battery
Can you use these types of battery on a normal road car or are they specifically designed for race car application only ? cheers
Old Sep 17, 2010 | 03:57 PM
scarnny's Avatar
scarnny
Hi iam also looking to use one of these because of having no room for a normal one. This is what I found.
Varley Red Top Racing Batteries offer an extremely high power to weight ratio. Combine this with a high resilience to shock, vibration and G-force, and you have the most desirable characteristics sought after in Motorsport. For this reason, Varley Red Top batteries are used by some of the biggest names within the industry such as Van Diemen, Tatuus Racing, Mitsubishi Motor Sport, Red Bull F1 and many more, making Varley Red Top the most popular and professional racing battery on the market.* Varley Red Top motor racing batteries are available only through specialist motorsport distributors who understand the various requirements of the different racing series and are technically capable of supporting the user.
I asume it depends on heaters/ aircon etc. What drain there is on it. I only need mine to start the engine, I think it would be ok for me.
Old Sep 17, 2010 | 04:49 PM
focus 4x4's Avatar
focus 4x4
good find ...... i have all the usual heated screens , cd , heater etc etc but no air con , so perhaps a normal battery is best for my car.
Old Sep 18, 2010 | 03:06 PM
The alt supplies the power once running, the red tops don't cope with not being used/stored very well at all, soon bugger up, a smaller AGM would be a better bet for a road car imo.
Old Sep 18, 2010 | 04:26 PM
STUCOS's Avatar
STUCOS
Use one on my cossie,spot on,mounted in the boot,doesnt seen to go flat like a normal battery,when you dont use car
cheeRS stu
Old Sep 18, 2010 | 07:30 PM
Porkie's Avatar
Porkie
correct... had one die on me for no reason and it was only used few times.
think they are best stored on battery conditioner.
my new one is working fine so far on Westy.
Old Sep 18, 2010 | 09:38 PM
285andy's Avatar
285andy
i use a varley 25 on my 100e. its been fine and ive never had to use a charger on it (yet). i left it in storage over last winter for about 5 months with it disconnected and went back to it, re-connected it and it started the car without problems. but ive heard if not used regular you should use varleys own charger/conditioner thing conveinently
Old Sep 20, 2010 | 08:09 PM
Wull79's Avatar
Wull79
Does anyone know what size of red top battery i would need for a 2ltr pinto powered mk1 escort, i have a rmd 25 on it just now but it doesnt seem powerful enough as the car will often not start, not sure if its just the cheaper rmd battery is not as good, stu porkie what size of battery is on your cars
JK12
33
Apr 26, 2021 12:09 PM
Bailes1992
Sep 3, 2015 02:17 PM
FordJonah
Aug 22, 2015 08:31 PM
