cannot get rearprop shaft to fit black 50p??????
Old Sep 16, 2010 | 08:24 PM
jonnyc's Avatar
jonnyc
Default cannot get rearprop shaft to fit black 50p??????
Just changing my saphire 4x4 gear box and trying to fit the rear prop shaft onto the black rubber 50p situatedon the outward end of mt75. It will only fit one way. ie the rods will pass through one set of 3 holes and not the other. The others seem just slightly out . the three rods attached to the end of the gear box will also only fit through the same three holes leave the other three useless in both cases. am i missing a trick?
Old Sep 16, 2010 | 08:51 PM
The Youth.'s Avatar
The Youth.
there are 2 types the early 4x4 and the esc cos IIRC
you may need to swap the rear tripod section off the old box
not certain of this but I have a hunch this is the case
steve
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
RockinRein
Aug 19, 2015 07:08 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
