Wiring an AMP meter gauge - help !
Old Sep 15, 2010 | 09:46 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Default Wiring an AMP meter gauge - help !
There is an amp gauge fitted in my car but not wired up - how do i wire this up ?
It has two terminals marked "BAT" and "ALT"
From this I assume i wire the "BAT" to the positive on the battery but as for the "ALT" do I wire this to a negative terminal on the alternator ? or am i completly wrong ?
Any help appreciated
cheers
Old Sep 15, 2010 | 09:59 PM
martysmartie's Avatar
martysmartie
Ammeters have to be wired in series I.E inline, I would fit in the battery live somewhere.
Martin
Old Sep 16, 2010 | 06:50 PM
s2turbsZVH's Avatar
s2turbsZVH
Martin
Sorry Martin - my electrics knowledge is probably not what it should be - can you give me an idiots guide as to where is should wire these two terminals ? - the gauge gives a +60 amp to -60 amp reading.
Old Sep 17, 2010 | 04:06 PM
martysmartie
You would have to cut a live wire and put one wire from the meter to one side and then the other to the other side so that it's going THROUGH the meter (Series) like a switch.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
gingeRS
17
Oct 2, 2015 09:42 AM
IainRS1700T
Sep 25, 2015 06:44 AM
