cossie fuelpressure
Old Sep 12, 2010 | 08:14 PM
bigturbokev's Avatar
bigturbokev
Default cossie fuelpressure
hi guys im new to the site but got a quickie for ya, im running a stage 3 setup on my 2wd cossie, but i was wondering what the fuel pressure is, cus on my guage it is about 3.5/4 bar, but on my wideband guage is reading 10.2, and i think thats a bit rich even on cold start or on warm up enrichment??
Old Sep 13, 2010 | 02:03 PM
10.2 is off the scale rich really.
You need to identify whose chip(make) it is and ask them what pressure the chip was written with, most are std rail pressure, 3 bar vac pipe on, about 3.6 vac pipe off.
It's vital the rail pressure is correct for the chip so just open up ecu and see whose it is.
Old Sep 14, 2010 | 05:02 PM
bigturbokev
i aint got a clue what chip it is to be honest, its a stage 3, but thats about it, so dont really know otherwise
Old Sep 14, 2010 | 06:57 PM
The ecu is a 5 minute job to take out and open up, prise out pad in dash where ecu hides, big philips screwdriver on the tabs at each end undoes the ecu, pull out slightly unplug pull all the way out, now remove the 4 top screws 1 in each corner, chip is in the corner can't miss it, the only one that is removable on a little holder affair, will have a label/writing on it.
Old Sep 15, 2010 | 08:18 PM
bigturbokev
ive had the ecu to pieces allredy, but there isnt a company sticker or any realinfo on it, just a non ledgible biro scribble on it.
Old Sep 16, 2010 | 07:47 AM
Does the chip have a SSS or 555 on it, some think they look like SSS others say 555, this would point to a std chip, that may have been re written, best bet is to get it on the rollers where afr can be seen under load etc, safest way of doing things from your point of view, just set to std pressure then get a fuelling load check done, cost 1 hours RR time but could save your engine.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
