servo pump seized?
Old Sep 9, 2010 | 07:56 PM
phil robson's Avatar
phil robson
Default servo pump seized?
chucked a new battery on the saff and got it started, been stood in garage for 4year!,
anyway brake pedal is rock hard at all times, abs lamp illuminated, servo pump is hot, red hot i burned my hand on it, thinkin pump is seized? anyone had this before?
Old Sep 9, 2010 | 08:15 PM
jon@work's Avatar
jon@work
Does the pump sound like it's working? May be a blockage in the low pressure fluid feed pipe.
Old Sep 9, 2010 | 08:16 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Sounds more like it's losing pressure, hence the pump running all the time. You could try changing the "bomb" first.
Old Sep 10, 2010 | 05:27 PM
As jon@work says is the pump running, making a whirring sound ?, it should stop after 20-30 seconds or so, if it doesn't there is a problem and if it runs continuously it's going to make it kin hot as it's not supposed to, has a very hard job to do.
If not whirring to start with and getting hot it is seized, so just have a listen, they're not quiet so will easily hear it even with bonnet shut.
Old Sep 10, 2010 | 08:51 PM
phil robson
will have another listen over weekend, dont think it made any sound at all, i didnt leave it running too long as i thought it could cause a fire!, dont think theres water gettin in anywhere as its been in garage for ages,
Old Sep 11, 2010 | 02:10 PM
phil robson
just been looking on ebay and there looks to be a few variations on the abs/pump unit even though all say 2wd, as where brake pipes go etc?
Old Sep 11, 2010 | 06:04 PM
Char1ie's Avatar
Char1ie
I've had one fail before. Sympton was no fluid coming from the three outlets where the brake lines connect. May be worth taking these off and pressing the pedal to see if fluid is flowing OK. If not, change the unit.
Charlie
Old Sep 11, 2010 | 06:52 PM
I'm sure reman can rewind the pumps/motor so they are as good as new.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
