Dipstick length
Old Sep 9, 2010 | 03:49 PM
chrisa3's Avatar
chrisa3
Default Dipstick length
Im running a 200 block in my 2wd cosworth, with the original 4x4 dipstick tube and dipstick. because im running with a 2wd sump, i need to calculate the appropriate max an min marks on thhe 4x4 dipstick.
If possible, can someone with a 2wd measure the length of:
a) dipstick tube from top to where it enters the block.
b) length from the 'max' mark to the start of the handle
c) length from the 'min' to the start of the handle.
This way I can compare the measurements to the 4x4 ones and work out the 2wd sumps max and min marks on my 4x4 dipstick....... i think
Old Sep 9, 2010 | 06:35 PM
I posted these up for someone about 4-6 weeks ago for a 2wd dipstick and dipstick tube, just do a search, it's not mega critical so long as it has enough, from empty 3.5 litres fills the sump and the shallow "tray" area to the front of the sump before the main flat bit, I filled one up in the week to find out.
3 litres filled the sump bowel itself and came to the top of the sump bowel area, so well above the baffle, in use some will remain at the top of the engine and in other parts, I'm just sticking 4 litres in, the in use level can be checked with a clear tube connected to the drain plug.
Old Sep 9, 2010 | 09:42 PM
chrisa3's Avatar
chrisa3
Done as you suggested, but cant find any posts with the actual measurements in. Can you put a link up please
Old Sep 10, 2010 | 05:41 PM
I'll re measure my dipstick for you and post up, watch this space.
DAZZER
Sep 30, 2015 08:43 PM
A.t.p
Sep 29, 2015 05:04 PM
Brickhouse
Sep 21, 2015 11:00 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
