Mk4 Fiesta Stoppers..
Old Sep 9, 2010 | 12:09 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Default Mk4 Fiesta Stoppers..
I'm anchoring after some better breaks on my little Fezza without having to buy aftermarket kits.
Any ideas for a reasonably cheap Ford item off something like a rs2000 maybe? All recomendations will be appreciated.
Ben.
Old Sep 9, 2010 | 12:12 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
What size wheels you got?
mk5 zetec s brakes are a direct fit,
I believe mk6 st 280mm brakes are almost a direct fit, need new lines iirc.
also mk3 300mm mondeo brakes also fit with st170 disks...
Old Sep 9, 2010 | 12:23 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Only 14's so room is an issue..
Old Sep 9, 2010 | 01:49 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
mk5 zetec s brakes are your best option then, as I doubt 280mm st's will fit. Unless you pick up a set of 15s? Can get zs wheels for like £100-200 then you can fit st brakes
Old Sep 9, 2010 | 06:38 PM
260 grooved with decent pads, ebc yellowstuff, braided lines will make a massive difference.
Old Sep 9, 2010 | 06:41 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i put si brakes from a 3.5 i was breaking, did the trick loads better than the unvented jobs
think frst etc are the same fitment, if not look for 1.7 puma, will be vented etc and easy to upgrade disks and pads when needed
Old Sep 10, 2010 | 09:51 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Does the ZS have discs all around?
Thing is, I've just had my steelies painted, cost me a bit so won't be upgrading wheels for a while unless a good deal comes up
Old Sep 10, 2010 | 11:35 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
no, zs only has 260mm front disks. You won't need disks on the back of a mk4 unless you've 2litre'd it tbh. They're more hassle than they're worth on fiestas.
Old Sep 10, 2010 | 12:11 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Ah, that's still a decent size disc really, i'll see what turns up, cheers all.
Ben.
Old Sep 10, 2010 | 05:34 PM
mk1 mondeo 2L only has 260 front discs and they are a lot heavier, same size as my xr4i had(till I cossied it!!), can't see you'd have a problem with 260 and the right pads/lines.
Old Sep 11, 2010 | 01:41 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
And would they fit under my 14's?
Old Sep 11, 2010 | 02:09 PM
Rcjm88's Avatar
Rcjm88
Zetec S Owners
ZS/Puma brakes will fit under 14" steelies, yes.
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
