IK31 iridioum denso or Qc57 champion
Old Sep 8, 2010 | 09:36 PM
mpales's Avatar
mpales
Default IK31 iridioum denso or Qc57 champion
My cossie has the usuall stage 3 conversion:3 bar map sensor,803 green injectors,program from motorsport dev.(stu),and i have adjust the actuator to hold 22 psi,and also 044 fuel pump.
Which spark plug is more suitable for 22 to 24 psi???????I have listen good words for the iridioum denso Ik31 but some saying its better when there is a group a coil
Now i have the champion qc57 but i am not very satisfy when the engine is cold
Is it worth to try Ik31???
Old Sep 8, 2010 | 09:45 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
i use the IK27 in mine with similar spec to yours but i'm not just sure either
Old Sep 8, 2010 | 09:47 PM
Thanasis's Avatar
Thanasis
hello,you can test the denso platinum with this code: K24 PR -ZU,i'm very happy with these to my engine,works perfect when it's cold,and i run msd closed loop chip with 1.9peak and 1.58hold boost,i hope this help.
Old Sep 9, 2010 | 06:29 AM
KSA-Cossie's Avatar
KSA-Cossie
IK27
Old Sep 9, 2010 | 07:30 AM
Imo IK31 are too cold, IK27 are a lot better, the QC57 foul very easily from what I've seen.
The IK will work a little better with a group a or similar coil, be smoother low down I found, idle slightly better, pull very slightly better low down as well is what I found.
SmudgerByName
52
Jul 28, 2016 06:14 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
pabloXR
Sep 21, 2015 12:42 PM
Si B
Sep 12, 2015 06:49 AM
Zoggon
Aug 10, 2015 10:39 AM
