breather return
Old Sep 8, 2010 | 07:54 PM
bad boy rs's Avatar
bad boy rs
Default breather return
Going to get an aero fitting welded into my new bigwing sump.
Does it matter what level its welded in at ? does it have to be submerged in oil so it doesnt breathe back up the pipe ?
cheers paul
Old Sep 8, 2010 | 07:59 PM
RS SHAUN's Avatar
RS SHAUN
Below oil level Paul!
Cheers shaun
Old Sep 8, 2010 | 08:16 PM
bad boy rs's Avatar
bad boy rs
thought so, how much of the atchual sump is full of oil though
needs to be on the opposite side to the turbo return is it ok at that level ?
Old Sep 9, 2010 | 07:33 AM
Doesn't matter which side, but needs to be returned in the oil itself ie not above otherwise it will act as a breather!!
The sump part of the sump takes 3.5 litres to fill to the top so it is just sitting on the shallow level, measured it a few days ago, 2" up from the base of the sump will be fine.
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
