Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Compressor Noise
Old Sep 8, 2010 | 07:21 AM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Default Compressor Noise
Hi Guys
Can you put a compresser in say a box stuffed with sound deadening.
I know it sounds silly but its for home use and i need to get it as quiet as possible.
Rob
Old Sep 9, 2010 | 01:07 PM
Sp3no's Avatar
Sp3no
Depending on the model you buy a compressor can be very quiet
Old Sep 9, 2010 | 03:47 PM
Ebonycossie4x4
how quiet?
Any models, and i dont want to be bent over on the price.
Old Sep 9, 2010 | 03:59 PM
RichieST's Avatar
RichieST
Mate of mine has done it with a generator for his garage, a wooden box wrapped in thick carpet, certainly makes a big difference!
Old Sep 9, 2010 | 04:53 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
mines dead quiet,210 ltr,sgl phase 18cfm,never hear it when it fires up......
lent it to a mate in middlesboro a little while ago
Old Sep 9, 2010 | 08:32 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
check with amusement parks if you can, they use SILENT running compressors on a lot of machines. I know someone who bought a couple for pennies and made a good one since they didnt know what to do with em.
His came from pleasure beach in blackpool. Its different to the regular motor and piston type. bit like a rotary engine...
Old Sep 11, 2010 | 07:29 PM
dakar's Avatar
dakar
If you want to enclosed a piston type compressor make the box so the lid can be lifted a little as the comp needs cool air to cool itself,if you dont do this they run hot a piss oil out everywhere if you flog it to death.Quiet air costs more mate.......vane compressors and screw compressor are quieter but can cost a lot more money
Old Sep 11, 2010 | 09:22 PM
RichieST's Avatar
RichieST
Mate of mine with the generator put a computer fan in one side and a small vent in the other, run it off the genny's 12v supply. Was more than adequate to keep it cool!
Old Sep 15, 2010 | 06:39 PM
Ebonycossie4x4
I was going to say could i not put a fan in the box and wire it in to give it some ventilation.
Its going to be a clarke best driven 150litre one.
What sort of noise are they, Its pretty professional!
Old Oct 2, 2010 | 07:28 PM
Etty's Avatar
Etty
if you want a quiet compressor buy a hydrovane, they are really quiet. some piston compressors do come in sound proofed boxes, they normally have 2 cooling fans built in. most piston compressor are really noisey, but if there belt driven they are quieter.
Old Oct 12, 2010 | 09:47 PM
an-dy's Avatar
an-dy
Some ideas on boxes on here that might be usefull.
http://www.mig-welding.co.uk/forum/showthread.php?t=17808
http://www.mig-welding.co.uk/forum/s...ad.php?t=13183
Andy
Old Oct 13, 2010 | 03:16 PM
3dr's Avatar
3dr
Get yourself a hydrovane compressor.
Old Oct 22, 2010 | 08:24 PM
fraser9764's Avatar
fraser9764
build a mini shed/lean to off the back of your workshop or garage, line it with big thick carpet etc, add a couple of fans, one sucking in and one blowing out, and pipe through the wall to a manifold with gauge bolted on the wall and run the cable through and plug it in inside so its easy to start/stop. job done.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gingeRS
17
Oct 2, 2015 09:42 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
