Gearbox oil leak
Old Sep 5, 2010 | 01:32 PM
neil_1821's Avatar
neil_1821
Default Gearbox oil leak
I've taken out a 1.25 zetec form a MK4 fiesta as it was knackered, but gearbox was fine. So I sourced an engine that had an auto transmission attached so was going to put the manual gearbox onto the engine to get a working unit (I know i need to put a new bearing on the crankshaft)
However while the manual gearbox has been stored there has been a spill of gearbox oil. According to the haynes there has been no drain plug fitted (what a brilliant idea, Not!) So it's either leaking out of somewhere it's not supposed to or will it be the same fluid and source for where the driveshaft enters the box as some leaked out of there when i seperated them?
If it is the same oil what would be the best way to drain all the oil and then fill it back up?
Old Sep 5, 2010 | 05:08 PM
lee81's Avatar
lee81
Gearbox on that car should be a b5 or Ib5 of some sort just like most of the ford range. It should have a drain plug and top up plug fitted. If not drained then most of the oil will piss out when the driveshaft are removed going everywhere.
If the gearbox is off then it should be empty. There should be a hex head bolt that once removed you fill the gearbox up through until it just starts to drip out. The oil fill level is the height of this bolt hole.
TPM961
Jan 15, 2018 10:50 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
