can Valve to piston contact damage be removed by pocketing?
As title, I stripped my engine down and the valves have hit the pistons only light marks on 3 but about 1mm down on No3, they are std mahle pistons so can i have pockets machined into them which would 1 remove the marks and 2 be safer in the future. Does this effect compression ratio?
You will only need pocketing if your going for a bigger inlet cam etc...
If your just worried about the marks you can just de-bur them..
If you have a high lift cam then yes you can have valve cut outs with no probs and depending on valve cut out size will depend on the cr,usually with a std size cutout this will lower cr around .3 so an 8.1cr will be around 7.8cr...
cheers danny
I Bought the engine second hand so dont know its history, i'm just concerned in the future with track driving etc it may hit again so thought i'd do it while i rebuild it, then either way it would be safe if i wanted to up the power and change the cams.
You can get clip marks when revved high enough, but never any amount other than a slight mark, can have them pocketed if thinking ahead you may want hairier cam, ie BD14/15.
Shop around a LOT for prices though, one place I asked wanted £9 + vat PER cut, ie £169.20p, wasn't going to use him just wanted quote, my regular guy did them for £40 everything inc vat, but he is a tad slow at times!!
borboyous
Aug 22, 2015 11:17 AM
