transit connect st 2.5
Old Sep 2, 2010 | 07:49 AM
stconnect's Avatar
stconnect
Default transit connect st 2.5
i am building a transit connect with the 2.5 focus st engine does anyone know what is the best managment to use or anyone that has done this and what might need to be done thanks
Old Sep 2, 2010 | 04:07 PM
atm's Avatar
atm
do a search mate, somebody started one earlier this year but havnt heard about it for a while.
Old Sep 2, 2010 | 04:25 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
do you have the runningear yet?
Old Sep 2, 2010 | 04:57 PM
stconnect's Avatar
stconnect
have most of the running gear need to sort what suspension going to use and managment
Old Sep 2, 2010 | 05:07 PM
COLEYST200's Avatar
COLEYST200
here is a link
https://passionford.com/forum/restor...-5-3-10-a.html
Old Sep 2, 2010 | 05:48 PM
stconnect's Avatar
stconnect
anyone heard if it was finished sent the guy a message to try find out
Old Jan 23, 2016 | 08:29 AM
Hamiltonleic's Avatar
Hamiltonleic
Did you find out? And did you ever do your connect?
Old Sep 7, 2019 | 05:58 PM
Dingdong76's Avatar
Dingdong76
Hi there I am currently taking in the same project. I am literally taking everything from the focus and transferring it to the van. Subframe, suspension, steering rack, engine, ecu, full braking system, which will include traction control and abs. Also fitting a rear disc axle from connect with an axle flip to lower it. Also need to fabricate the pedals to fit as the focus ones are too long so using the transit brake and clutch and making the focus throttle pedal fit. It’s quite an involved job but will be worth it when finished. Also keeping the tank but flushing it out and using focus sender unit and new fuel lines. Keeping the van tank will hold more fuel than the focus one which will come in handy! Do you get yous done?
Old Sep 20, 2020 | 06:07 PM
Turbomonkey1's Avatar
Turbomonkey1
Hi I’ve just started my 2.5 conversion on Friday when I got back with the st. And I’m wondering if any body has done it yet. I have the engine in and subframes on(still to make some adjustments) and steering rack fitted just got to run the interior loom do the sender unit and fuel lines. im debating on getting a peddle Assembly to make it easier to fit the steering column. Some pictures would be help full if any one has got that far please
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
stevecfrst1
Sep 30, 2015 05:18 AM
