Stainless exhaust cleaning. Best way?
Old Sep 1, 2010 | 06:30 PM
T666 FRS's Avatar
T666 FRS
Default Stainless exhaust cleaning. Best way?
Hi guys, recently bought myself a series 2 and the rear section of the exhaust looks like it's never been cleaned.
Are there any good methods or products that I can use to bring the shine right back?
Cheers in advance
Old Sep 1, 2010 | 08:29 PM
jock05's Avatar
jock05
Fine steel wool and Autosol or Megs NXT all metal polish
Old Sep 5, 2010 | 04:40 PM
I wanna do my tail pipe on my car too cause thats a bit poo.
Old Sep 5, 2010 | 04:42 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
tin foil and some hot water works for a tail pipe gets all the black off the inside of pipe
Old Sep 21, 2010 | 08:15 PM
Retro Al's Avatar
Retro Al
RWD IS KING
What jock said
Old Sep 22, 2010 | 07:07 AM
daver555's Avatar
daver555
Alloy wheel cleaner works well but be carefull with acid based versions and don't leave on for too long. For the really caked on stuff as said before, fine steel wool but forget autosol and similar others use Brasso as it's a much finer abrasive and imprortantly cheap as chips.
Old Sep 22, 2010 | 11:10 AM
Cossy Mike's Avatar
Cossy Mike
Depends on how bad it is....
If it's really bad, having loads of shit on it and going Blue and Yellow get at it with a wire cup brush on an angle grinder first.
Soak the thing in WD40 for about an hour then simply skim over it with the grinder to bring the true colour back then use wet'n dry sand paper 1800 grade with Autosol,
THEN use soft cloth to buff it.
Don't waste your money on autosol if it's bad to begin with, you'll use tubes of the stuff....
Old Oct 11, 2010 | 09:50 AM
megachithu's Avatar
megachithu
For items like kettles that don't get filthy,
Hot water with Lemon or distilled white vinegar will remove limescale from chrome and stainless steel.
For items such as cookers that get very dirty,
~Wash surfaces with hot, soapy water (dishwashing liquid is fine) and a nonabrasive sponge, working both with and against the grain (yes, stainless steel has a grain) to lift buildup. Dry with a towel. Don’t be alarmed if appliances look duller than usual; you have just removed kitchen grease and residual cleaning products.
~Apply a layer of stainless-steel polish according to the package directions, wiping off any excess immediately. (available at any supermarket)
~With a clean, dry towel, buff the polish into the surface, going with the grain, until it shines and the towel comes away dry.
Elektrofahrrad Pedelec
how to paint your car
Old Oct 20, 2010 | 07:38 AM
jonusb4's Avatar
jonusb4
Weighing these two arguments, I ny asian escort prefer to the latter one. In my eyes, ny asian escorts though “the moonlight clan” may acquire temporary satisfaction from their consumption, in ny escorts the long term, it is unfavorable to their family and career. Just as a proverb says, one should ny escort always prepare for a rainy day.
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
