best way to store an engine block
Old Aug 31, 2010 | 06:54 PM
gus's Avatar
gus
Default best way to store an engine block
i just brought a cvh block for me to build a spare engine with
it wont be getting used until things pick up again at work so will be some time yet
whats the best way to store it?
would covering it in grease be ok? or that rust prevention paper?
any tips?
thanks
gus
Old Aug 31, 2010 | 06:58 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
I oil mine up and rap um in industrial role cling film lol
does the trick
Old Aug 31, 2010 | 07:05 PM
Luca's Avatar
Luca
Lukesville
Just put it in the S1, you have stored one in there for ages and its MINT!
Old Aug 31, 2010 | 07:08 PM
st3v3's Avatar
st3v3
oil it up all over and where ever theres a hole,inside it, wrap it up and bobs your aunty with bollocks.
Old Aug 31, 2010 | 07:21 PM
jamie's's Avatar
jamie's
wd40 all over it, bores oil gallery's, water holes etc
then wrap it in clingfilm, works a treat, keeps the moisture out and wd in
Old Aug 31, 2010 | 07:32 PM
gus's Avatar
gus
could do, there is a lump missing in there now as original engine is out again
Old Sep 1, 2010 | 08:39 AM
BLACKCOS's Avatar
BLACKCOS
oil and grease it all up then rap up in cling film. Spray grease works well
Old Sep 1, 2010 | 08:47 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Oil it up is the key, they rust very quickly if you leave the machined faces exposed.
Old Sep 1, 2010 | 09:41 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Cover it in WD40 and airline the worst of it off. Will leave a good film on without it being dripping wet/forming puddles.
Old Sep 1, 2010 | 10:09 AM
ECU Monitor Enthusiast
I wouldnt use WD40 as a long term lubricant or moisture protection as it will evaporate with time.
Old Sep 1, 2010 | 10:13 AM
Luca's Avatar
Luca
Lukesville
Just store it somewhere warm and damp free covered in some sheets.
Under the bed?
Wardrobe?
Loft?
Old Sep 1, 2010 | 12:04 PM
nigel b's Avatar
nigel b
de watering oil works well
Old Sep 1, 2010 | 12:32 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
So i should be storing my 200 bottom end in a better fashion than just in the corner of the garage upside down on a bit of carpet? lol
Old Sep 1, 2010 | 12:42 PM
.Ross.'s Avatar
.Ross.
Buy some Coloured Spray on grease ..
LIKE THIS!
Old Sep 1, 2010 | 12:50 PM
markc's Avatar
markc
my orion was laid up for 4 years water drained and left (plugged up all the holes tho).
when i come to use it again ended up getting blow by on 1 cyclinder so rust had got on to the liners
Old Sep 1, 2010 | 04:41 PM
whosyadaddy's Avatar
whosyadaddy
as said above some spray on grease etc and lightly spray it on all machined surfaces and if you feel it necessary wrap it in cling film.
Old Sep 1, 2010 | 05:31 PM
gus's Avatar
gus
cheers chaps
with the spray grease do i just cover everything, bores, water ways everything
is the anti corrosion paper (what you get on brake discs) worth doing?
Old Sep 1, 2010 | 05:46 PM
andy130's Avatar
andy130
do not use wd40 as it will rust in no time,
original
Apr 28, 2026 05:20 PM
big_Rad
Sep 15, 2017 09:36 AM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Zoggon
Aug 10, 2015 10:39 AM
