Escort RS turbo running on 2 cylinders
Old Aug 31, 2010 | 05:04 PM
lee81's Avatar
lee81
Default Escort RS turbo running on 2 cylinders
Hi its running MFI
When driving a couple of weeks back it started to lose power but remained running poorly. No smoke or bangs and all fluid are fine.
When opening bonnet it appears there is no power stroke on piston 1 and 2. When removing the plug lead from these it make no diffrence. Pistons 3 and 4 are running fine and pulling these off will stall the engine.
Have checked and swapped plugs and leads around which makes no difference. A spark is jumping the gap between plug and lead on pistons 1 and 2 when the lead is placed close so I think its still getting spark.
Also wouldn't think injectors would fail two at the same time.
Am not sure on whats happened. Most parts are realtivly new and it gets a regular set up once a year. Has to this date ran spot on not missing a beat.
Any ideas would be welcomed as i'm not sure which area to look at
Old Sep 3, 2010 | 08:58 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Best to get it to a tuner and let them diagnois it for you properly.
Old Sep 4, 2010 | 09:47 AM
lee81's Avatar
lee81
I'm just looking for ideas on the problem, do all the work on car myself bar mapping. Am going to break car soon and would ideally like to find the problem before selling the parts on that may be faulty. Think i might do a compression test and go from there.
Have a MK4 RWD cosworth powered cabby now so aint going to restore this one anymore
Old Mar 23, 2011 | 08:53 PM
cobrarally's Avatar
cobrarally
Hello mate just wondering if you ever sorted out ur misfiring problem i have the same problem just on 3 and 4 cheers chris
Old Mar 23, 2011 | 09:25 PM
lee81's Avatar
lee81
I havent had chance to look and start striping the car yet. I'm now thinking that the head gasket has gone between cylinders 1 and 2. Hence no fluid loss but the power strokes are gone from two cylinders.
When turning the engine over you can feel resistance as cylinders compress twice ever two rotations of the crank. Should be four for every two rotations of crank.
Anyone know if this is a common failure point on rs turbo engines?
Old Dec 10, 2011 | 09:08 AM
Bransby's Avatar
Bransby
Sorry to drag this up from
the dead but I've got exact same problem as first stated on cylinders 1 and 2 but when I pull the leads off 1 and 2 and just have the lead really close the plugs will fire again, the plugs and leads are brand new, I've swaped them around and no diffrence, I've since stripped the head off last night and I'm going to do a full head rebuild and fit a payne head gasket and stretch bolts, is there anything like a paste you can use on the gasket to help it seal better?? Cheers Ryan
Old Dec 10, 2011 | 09:34 AM
lee81's Avatar
lee81
You shouldn't and will never need a paste to seal a head gasket. Your better off getting a decent head gasket such as cosmetic or a group B item which is what i had. It lasted 35K on a engine that wasn't in good state producing 200bhp
druidgetafix
Aug 15, 2015 10:22 AM
Churtz
15
Aug 13, 2015 06:40 PM
Zoggon
Aug 10, 2015 10:39 AM
turbobill
Aug 9, 2015 05:21 PM
adriansaleem
Aug 1, 2015 09:28 PM
