how to take a tracker off!!
Old Aug 30, 2010 | 11:15 AM
morto's Avatar
morto
Default how to take a tracker off!!
ok im looking at taking my tracker off , im not going to be activating it and have a very bad battery drain, ive only just bought the car and new this when i bought it.. looking back at all the paperwork it hasent been activated in over 6years, ive looked on other forums and people have had this same issue of battery drain cus of the tracker, if the tracker battery's are fucked it will be constantly using the main battery, any help on location are were to start
andy
Old Aug 30, 2010 | 11:17 AM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Thief!!!!
Old Aug 30, 2010 | 11:25 AM
S1's Avatar
S1
The whole point of tracker installations is they go somewhere random, no point putting them all in the same place otherwise they're too easy to rip out. You just have to start stripping the interior until you find it. Could be behind the dash or rear quarter trim or boot etc. Once you find it trace the wires back to wherever they're spliced into the loom and remove them from there, recover the loom with some heatshrink or self-amalgamating tape.
Old Aug 30, 2010 | 11:29 AM
morto's Avatar
morto
thanks mate, as said it hasent been activated in over 6 years so the battery's will deff be no good , will start to look
andy
Old Aug 30, 2010 | 11:30 AM
Jasesapphy's Avatar
Jasesapphy
Both mine were in centre pillers where seat belt goes
Old Aug 30, 2010 | 12:25 PM
Mk4 Lew's Avatar
Mk4 Lew
like that dosnt sound dodgy lol
Old Aug 30, 2010 | 03:26 PM
morto's Avatar
morto
lol.. stu has my name and addressee ive had my s2 worked on many times by kenny a few years ago.. lol........
update on this took me around 45 mins to find one tracker that has GSM and gps.. but i now think there could be 2 trackers on this as all the info on it dont relate to www,tracker.com
unless they used this equipment back in 2002
andy
Old Aug 30, 2010 | 03:29 PM
Mk4 Lew's Avatar
Mk4 Lew
it like what my mate saw on ebay a car with a smashed window and no ignition barrel
Old Aug 30, 2010 | 03:35 PM
rubinsbin's Avatar
rubinsbin
just leave it ------------why would you want to remove it????
tracker wont tell you either where it is
Old Aug 30, 2010 | 03:54 PM
morto's Avatar
morto
do you think im taking it off for fun mate!! they use rechargeable battery's, the units over 6 years old could be as old as 1999, i have a battery drain , the tracker will be constantly charging the old battery's and now i found there could be 2 units on this car, now wonder it wont hold charge
Old Aug 30, 2010 | 06:18 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you could always use one of them drain clamps to follow the wires
i'm not sure what they are called but they have a readout and a spring loaded claw thing that detects current drain
got to be easier than poking a tester into random wires looking for the power
Old Aug 30, 2010 | 06:22 PM
morto's Avatar
morto
thanks mate!!! will google one and have a look,,,,
andy
Old Aug 30, 2010 | 06:27 PM
fiestaturbo1984's Avatar
fiestaturbo1984
always noobs with the stupid comments. i found mine by mistake last week when strippin out my subaru
Old Aug 30, 2010 | 06:36 PM
My one is around that age and even left for 4 weeks still starts with it and cat 1 being left, it does turn over ever so slightly slower but nowhere near slow enough not to start, maybe just get a decent battery ?, if not used much try a AGM battery will be a massive improvement but kill the wallet!!
Old Aug 30, 2010 | 06:45 PM
vaughant's Avatar
vaughant
the device your looking for is called a clip on ammeter,but if youve got an okayish multimeter,you`ll have an ammeter on that. I`m with tabetha that its highly unlikely to be a tracker causing it,mine wasnt activated on the scooby for years and it never drained my battery once,again with a cat 1 etc on it.
The ammeter section of your meter usually requires you to swap the red lead into a different part of your multimeter and you then put it into series with your car battery to see how much current your battery is draining.
If you then start to remove fuses the current should drop off when you find the faulty circuit and then you can trace it back from there.Usually its something like a boot light staying on but i`ve known heated rear screens to get stuck on with a faulty switch contact but not display on the switch/dash etc.An old sound system not removed correctly can also cause probs.
Old Aug 30, 2010 | 07:00 PM
morto's Avatar
morto
have read on different car forums and alot of people have had loads of trouble with trackers and battery drain, the rac trackstar is very bad for battery drain ive just been on scooby net and there is alot of posts about the trackstar and they do have rechargeable batterys and once they go they drain the main battery
Old Aug 30, 2010 | 07:07 PM
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
What does it even look like...?
Old Aug 30, 2010 | 07:10 PM
Mine is a trackstar, the other tracker isn't though, I've used these for nearly 15 years and never had issues.
A lot get blamed when not at fault, alarms with lots of add ons, ie cliffords etc can take a serious hammering to your battery.
For the record I use a VARTA BLUE DYNAMIC battery 095, 72ah, cost me Ł50, but 5 year warranty.
Old Aug 30, 2010 | 07:15 PM
morto's Avatar
morto
has anyone herd of a DanTrack DT-100 this is one of the trackers i found, its GSM and gps, but is very old
Old Aug 30, 2010 | 07:16 PM
vaughant's Avatar
vaughant
Mine was a proper tracker so maybe thats why it was ok?you can still test it all the same way as unless its wired absolutely directly from the battery or ignition perm live then its more than likely been put through a fused circuit somewhere,if its for something you dont use very often then you could just remove the fuse therefore disabling the wiring to it,save ripping it all out then.
Old Aug 30, 2010 | 07:19 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
if you find the box probe the wires til you find the live 1 then cut and tape it, dont fuck with the rest of the wiring, just take out the feed
may need to put it back 1 day too
i know very little about trackers but i do know if you wanted to get round one Ł50 buys you the kit to do it off many websites
Old Aug 30, 2010 | 07:21 PM
morto's Avatar
morto
this has the proper tracker on it mate, ive got all the paperwork for it and it was last activated around 2005..
Old Aug 30, 2010 | 07:29 PM
vaughant's Avatar
vaughant
If your not 100% about the wiring,i`m sure an alarm specialist could remove it for you?
Old Aug 30, 2010 | 09:11 PM
dojj's Avatar
dojj
our vans have trackers in them, with a chip and everything with live data recall etc
Ł7 a month for the sim and it's been the fault of many a battery drain as it's on ALL the time, with the engine running it transmits every 30 seconds or so, with the engine off it transmits every hour so after a few days sitting on the side it kills the battery
Old Aug 30, 2010 | 09:20 PM
1.9 xr2 on 40's
st170 breaking
my company didnt want to pay the Ł14 per year for our vans (prob about 100 vans i guess), happy days
and ford removed the speed limit when it wa serviced last too
awesome
Old Aug 31, 2010 | 07:44 PM
morto's Avatar
morto
thers deff 2 trackers on this car the one ive found is a DanTrack DT-100 here is a right up in 2003 from the scooby net..
http://bbs.scoobynet.com/security-16...o-car2car.html
and says..
Communication between you and your DanTrack DT-100 is extremely convenient and fast: simply use your GSM. Call your DanTrack DT-100, or send an SMS, and within seconds you will see the accurate coordinates in the telephone display. This puts you in full control because you can track your vehicle within a margin of only 15 metres – anywhere on earth.
1. You read the exact coordinates in the display of your GSM phone.
2. Then you look up www.dantrack.com on your computer and enter the coordinates.
3. DanTrack’s WebMap flashes a clear, red dot at the exact location of your vehicle – wherever you are in Europe.
NO SUBSCRIPTION FEES
One investment is all it takes to secure your valuables in future.
There are no alarm centres involved. You are in full control thanks to the direct communication between you and your DanTrack DT-100. So a DanTrack DT-100, a SIM card from your telecom and DanTrack’s WebMap are all it takes to know exactly where your vehicle is. And gone are all the other costly tracking solutions.
so this is deff not a tracker as in www.tracker.com.. so there must be 2
andy
YODI
Aug 30, 2015 01:12 PM
Porkie
30
Apr 3, 2006 06:03 PM
Shings
Mar 31, 2006 05:37 PM
Jim Galbally
14
Aug 10, 2005 09:45 PM
GINGA
71
Oct 1, 2004 08:49 PM
