Another issue with gear selection on ford escort
Old Aug 29, 2010 | 07:55 AM
johnopaulo's Avatar
johnopaulo
Default Another issue with gear selection on ford escort
Hi Again folks,
I have another question about my newly aquired ford escort soft top. It is a 'G' reg and I have a question re gear selection. It is difficult to engage 5th gear and reverse gear, all other gears are fine. This happens cold or warm. Any Ideas?
Cheers Again
Johno
Old Aug 29, 2010 | 12:38 PM
STeve's Avatar
Super Moderator
the mk4s used to suffer with gearbox issues as doubtfull its the selector or a poss clutch
Old Aug 29, 2010 | 01:19 PM
keldsyke's Avatar
keldsyke
Originally Posted by johnopaulo
Hi Again folks,
Cheers Again
Johno
Many moons ago when I worked at a Ford dealer in the mid 80's early 90's this was a common problem when a box or clutch had been changed. We would put the vehicle on a lift, select 5th gear and then loosen the 10mm nut and bolt on the gear linkage and then re-tighten. 7 out of 10 times it would cure the problem.
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
