mk2 escort pinto what gearbox?
Old Aug 28, 2010 | 08:39 PM
escortdrifter's Avatar
escortdrifter
Default mk2 escort pinto what gearbox?
i have just purchased a t plate mk2 escort 1.3 popular plus, i have a pinto lying around i want to bung in it, what gearbox will fit without modifying the tunnel?
Old Aug 29, 2010 | 07:49 PM
cabriolet's Avatar
cabriolet
not quite that easy fella unless its automatic [they have big tunnel already] the gearstick hole is in the wrong place and the tunnel is not wide enough if u cut the stick hole as a oval u can refit it the other way round big hammer in the tunnel jobs a good un sierra 5 speed is the best fuel pipes on the wrong side alternator wiring on the wrong side best of luck
Old Aug 30, 2010 | 01:47 AM
D3LLB's Avatar
D3LLB
You can now buy lowering blocks for the mouuning of the gearbox so the it will fit in the tunnel, i think!
Old Aug 30, 2010 | 05:53 AM
rubinsbin's Avatar
rubinsbin
t5-t9
Old Aug 30, 2010 | 07:34 AM
retro d's Avatar
retro d
The t5 g/box is to big for what you want tbh and the tunnel will need do be modified.
Stick with the type9 is you best option, as above you can buy the lowering blocks for the g/box mount. cut the top for the g/stick and flip it round.
Old Aug 30, 2010 | 03:51 PM
keldsyke's Avatar
keldsyke
Type 9 ( 5 speed ) or if you want a 4 speed 'Type E' ( Rocket ) there are some good gear kits with good ratios out there to suit
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Ben26
Aug 27, 2015 08:56 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
