Bad feedback
Old Aug 27, 2010 | 09:16 PM
burnhamshaun's Avatar
burnhamshaun
Default Bad feedback
In my escort cabriolet I have just put a new live amp wire in changed the amp and added a power cap but kept the same earth I've also run another set of Phono leads and for some reason when I start the car all I get is really bad feedback like the engine sound coming through the speakers what have I done wrong
Old Aug 28, 2010 | 08:57 AM
cabriolet's Avatar
cabriolet
EARTHS EARTHS EARTHS then check all yr new leads and move them away from sources of interfereance then check the surpressors on the alternator fella
Old Aug 28, 2010 | 04:46 PM
RichieST's Avatar
RichieST
Get rid of the power cap, it does nothing. Make sure the RCA's run down the opposite side of the car to the power cable, make sure the earth is nice and clean.
Old Aug 28, 2010 | 05:38 PM
burnhamshaun
right i have run a power cable round the outside of the car passenger side run an earth round the drivers side to the battery rca's down the middle with the remote wire and on the inside of the car i tried the same i have all the seats out and carpets ive tried earthing it to the car in many places tried differnt leads and different amps and still the same ;-( the annoying thing is it was fine untill i changed the power lead amp and added 1 set of rca's what is a suppressor when its at home
Old Aug 28, 2010 | 06:32 PM
cabriolet's Avatar
cabriolet
exactly what it says it cuts down [ie surpressses the exact noise u r fighting with] it is usually a rectangular black or red plastic box bolted to yr alternator and connected to yr battery charge lead 6mm stud if later car or independent spade connection on 3 pin plug early type
Old Aug 28, 2010 | 06:50 PM
burnhamshaun
So why would I now have this problem and how do I go about solving it need to try and get it sorted tomorrow advice please
Old Aug 28, 2010 | 07:10 PM
STeve's Avatar
Super Moderator
I hope you meant run it OUTSIDE the car for testing purposes only,as escorts have a huge grommet behind the wheel arch liner which can take any sized power cable with ease into the cabin area ,have you also thought the new leads may be faulty ?
Old Aug 28, 2010 | 07:15 PM
burnhamshaun
Yea lol just to try it to see if there was a problem inside the car I've tried different RCA leads and still the same problem
Old Aug 28, 2010 | 07:20 PM
RichieST's Avatar
RichieST
Did you disconnect the RCA leads before you started disconnecting/reconnecting the power cables? If you accidently touched the positve lead against the earth then its quite likely it'll send the current back down the head unit to blow an earth track inside. Have you got another head unit you can try?
Old Aug 28, 2010 | 07:21 PM
STeve's Avatar
Super Moderator
it will come down to a process of illimation,even try another stereo if you can
Old Aug 28, 2010 | 07:29 PM
burnhamshaun
I've got another stereo I can try but if this was the case would it not be abnormal even with the engine of as I only have this problem with the engine running
Old Aug 28, 2010 | 07:30 PM
Sp3no's Avatar
Sp3no
I had this in my Focus, alternator noise through the speakers, as the revs increased so did the pitch of the sound, it was the earth, i sanded the area around the earth back to bare metal and bolted it down.
Old Aug 28, 2010 | 07:41 PM
burnhamshaun
Thing is I've tried 3 different earths and I've even earthed it back to the battery and still the same
Old Aug 29, 2010 | 05:57 PM
burnhamshaun
Will this be the answer to my problems or is this the wrong item. http://www.nexxia.co.uk/product.asp?...on=Car%20Audio
Old Aug 29, 2010 | 05:59 PM
burnhamshaun
Or do I need this one. This problem is really getting me down now
Old Aug 29, 2010 | 07:49 PM
RichieST's Avatar
RichieST
Have you tried a different headunit yet?
Fordmad!
Sep 29, 2015 07:03 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Minirotty
11
Sep 15, 2015 10:16 PM
