Few questions on mk4 esc cabby rst conversion
Old Aug 25, 2010 | 04:10 PM
mill5y's Avatar
mill5y
Default Few questions on mk4 esc cabby rst conversion
Hey up guys, I'v decided to go down the rst route with my cabriolet (purely for boost and dump valve) I'm in no rush to complete the project and will be bare shelling it and making it immaculate before rebuilding. So my questions:
If I found a full escort rs turbo Everything will just swap straight over? Are there any major differences with it being a convertable??
Fueling, Can I use the cut off switch from a mondeo to stop my fuel pump relay getting warm and melting itself??
Brakes/suspension, Do I/ can I use Rst suspension or normal 3i convertable suspension? And Brake wise is it possible to use bigger brakes from say a cossie? Or is it just easier to buy a big brake kit?
Cheers guys and thanks in advance
Old Aug 25, 2010 | 04:15 PM
rsbenj1's Avatar
rsbenj1
not really any probs i done 7 conversion every thing bolts in place as it does on the rst and never had problem with my cabby fuel relay but some do
Old Aug 25, 2010 | 04:54 PM
s1cab's Avatar
s1cab
everything will basically drop stright in with no issues.. as for brakes look in the 'escort rs turbo' forum and one of the top 'sticky' threads it explains/shows you exactly how to do it, a very easy conversion. 4x4 cossie callipers, 2wd cossie discs and 1mm spacer washer and bolt it all on and ... job done
Old Aug 25, 2010 | 05:02 PM
155lee's Avatar
155lee
if your cab has an electric roof,heated screen,alarm it may be easier to use the engine loom and splice it into the cab loom.thats how i had mine done.
as for teh brakes,rst discs are bigger and so are the drums,but they are still pish.check the sticky in the rs turbo section,if you get cossie calipers from a granada you might get them cheaper than cossie 4x4 but they are pretty much the same but the 283mm dics needs machined down to 278mm as thats the diameter of the 4x4 disc.rear conversion is easy with the brackets and 9mm spacers.
all fuel lines are the same,tank and pump are the same,exhaust,suspension,rad,intercooler and gearbox all bolt up the same.will be very easy with an escort and your cab side by side.
Old Aug 25, 2010 | 07:14 PM
mill5y's Avatar
mill5y
Cheers guys, I suppose I should start poking around the rs turbo threads now and start getting some ideas.
It's a 1987 d reg so no heated screen etc. Planning on modding the interior so dash will be removed so I'l just swap the full loom over while it's out.
Old Aug 25, 2010 | 08:06 PM
s1cab's Avatar
s1cab
i have spare running gear
Old Aug 26, 2010 | 07:21 AM
rsbenj1's Avatar
rsbenj1
well if you need any help am in doncaster
Old Aug 26, 2010 | 08:52 AM
Toe Knee's Avatar
Toe Knee
I've got uprated front brakes and a rear disc conversion kit for sale if ur interested mate, came off mk4 cabby. And has all the spacer washers etc, pm me if ur interested )
Prickly_buzz
Dec 7, 2017 09:52 PM
`spotty
Sep 25, 2015 11:41 PM
liamT74
Sep 23, 2015 10:24 PM
Chopshop85
Sep 18, 2015 06:13 AM
Billy_RS
Sep 13, 2015 04:17 PM
