pressure in my crank
Old Aug 24, 2010 | 08:56 PM
gandi4ross's Avatar
gandi4ross
Default pressure in my crank
I have a 1.8 zetec turbo but have got pressure in the crank and there is oil coming out of the crank breather any advise would be much appreciated.
Old Aug 24, 2010 | 09:15 PM
lacey's Avatar
lacey
hello mate , it could be your piston rings are worn and your getting blow by
Old Aug 25, 2010 | 06:54 PM
What he^^^ said, check your breather system is clear first.
Old Aug 25, 2010 | 07:27 PM
gandi4ross's Avatar
gandi4ross
by breather system do you mean the crank breather if so done that......
Old Aug 26, 2010 | 09:48 AM
Yes crank breather, if you still have lots of pressure it points to bore/ring wear.
Old Aug 26, 2010 | 08:58 PM
gandi4ross's Avatar
gandi4ross
if it is the rings is it a big job to do? or is it worth a garage doin if so wat am i looking at a garage charging.....?
Old Aug 27, 2010 | 10:02 AM
Easy diy job, a lot of work but nothing difficult really if you're a good diyer ?
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
timsrs
22
Sep 24, 2015 08:14 PM
pabloXR
Sep 21, 2015 12:42 PM
Dubs44
Sep 19, 2015 06:31 AM
