help needed with gearbox
Old Aug 23, 2010 | 10:35 PM
blackbeautyzetec's Avatar
blackbeautyzetec
Default help needed with gearbox
hi guys please help,
the diff went in my focus 2.0 so got a new box and fitted it.
the gears are different as in they go a different way(side to side instead of up and down, im guessing this is because the box must be from a 2000 model and mine is a 2002.
can i take the gear leaver and selector cables from the 2000 model and fit it.
the cables just dont fit right
you can get 2 different types
2000-2001 new box
2001-2005 mine
im guessing if the cables are changed it should all work as they are both mtx-75 boxes and off a focus just the selector cables are different lengths
anyone shed some light?? please!
Old Aug 24, 2010 | 01:57 AM
focusrrx87's Avatar
focusrrx87
you need the type 35 tower and linkage (1999-2001) now you have the early box in.
Old Aug 24, 2010 | 09:32 AM
blackbeautyzetec
Wil it fit strait on?
Old Aug 24, 2010 | 10:49 AM
blackbeautyzetec
Right the gearbox is out of a 2002 As well.
What's goin on!?
Old Aug 24, 2010 | 10:54 AM
chaffe's Avatar
chaffe
Turbocharging Technician
just swap the diffs.
Old Aug 26, 2010 | 02:41 PM
Colin_P's Avatar
Colin_P
I've been through this on my diesel although it uses the same MTX75.
I swapped round the selector mechanism on the gearboxes from the later back to the early in my case. Saved having to mess with the cables.
Newer type shown in photo. Older type is a quick straight swap or was on my TDDI, hopefully the 2.0 petrol is the same.
Old Aug 26, 2010 | 05:20 PM
blackbeautyzetec
Nice one mate that's just what I wanted to hear. I had the same idea and took the selector off the old box and they work the same way as in up 2 middle 2 down 2 so should be the same internals. Were see tomoz
Top bloke Colin!!
Chas
Sep 21, 2015 08:57 PM
cos elle
Sep 1, 2015 06:48 PM
Ben26
Aug 11, 2015 04:19 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
